Weight of Hotchkis (steel) rear LCA's vs Currie Currectrac (alum
Old Jun 18, 2011 | 04:05 PM
oldzy's Avatar
Just a FYI in case anyone is interested. Had a chance to weigh both.
Hotchkis Lower Control Arm 64-72 GM A-Body (pn #1302)
- Tubular steel (.120" wall)
- 9.60 lbs
Currie Currectrac Lower Control Arm 64-72 GM A-Body (pn #CE-7011LA)
- Solid billet 6061-T6 Billet Aluminum
- 7.22 lbs
Old Jun 18, 2011 | 04:14 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Are those Currie pieces similar to the Metco bars?
http://www.metcomotorsports.com/products.asp?cat=94
Old Jun 18, 2011 | 04:20 PM
oldzy's Avatar
Look similar (more of a dogbone shape on the Currie ones though). Currectrac has a poly bushing on one end, and a joint on the other. Currectrac's are $100 more, come with no H/W, no instructions, and poor packaging (loose inside and both grease joints went right through box). I will give that to Hotchkis though... they had great packaging on their arms (formed foam all around), same with sway bars.
Old Jun 18, 2011 | 06:16 PM
- 7.22 lbs
- 9.60 lbs
That's pretty funny, but not unexpected. Steel and aluminum have the same specific stiffness (stiffness per pound). For two beams with the same moment of inertia and the same bending stiffness, the two will be the same weight if the designs are optimized. In this case, the aluminum arms are limited by machining and thus heavier than the steel. Personally, I'd go with steel box beam arms as the stiffest in both bending and torsion for the weight.
Old Jun 18, 2011 | 07:23 PM
oldzy's Avatar
I would/did go with steel as well, but the Hotchkis arms are 1.5" wide and hit my axle mounts while the frame is on stands. The Currectrac's are 1" wide, and seem ok so far gap wise, although I have not torqued anything yet.
People say my rear end is warped or something... but I don't buy it. It is obvious when you look at the lower rear control arm axle mounts, they are offset (although I don't know why) which is the cause. Perhaps mounts are diff on diff rear ends.
Old Jun 19, 2011 | 07:56 PM
oldzy's Avatar
Sorry all... i reversed the lb figures. Hotchkis are 9.60 and Curries are 7.22 lbs. Duhh.
big_wheel1971
Suspension & Handling
Jun 28, 2011 07:15 PM
oldzy
Jun 7, 2011 12:11 PM
BerBer5985
17
Sep 24, 2009 11:26 AM
