suspension on 69 442
Old Dec 3, 2015 | 06:18 AM
kschwartzy1's Avatar
Have a 69 Sport Coupe, would like to redo the entire suspension. I have looked at after market kits that seem to have everything needed. Is there some better than others? Any suggestions? Any thoughts would be appreciated. Thanks.
Old Dec 3, 2015 | 10:26 AM
mpolds's Avatar
Suspension
MOOG and only MOOG ---- For "stock" Front Ends --
more expensive than the chinkily - made garbage --
but well worth it -- once for life.....
Old Dec 3, 2015 | 02:02 PM
Welcome to the site, how you do your front end depends on what your looking for. What are you planning to do with your car, just cruise, road rally, drag strip?
Old Dec 4, 2015 | 06:59 AM
Looking to mostly cruise, maybe race a buddy or two, no serious track racing. At least not for now.
Old Dec 4, 2015 | 07:12 AM
Then I would just replace the worn parts with Moog. You can either buy them from your local auto parts store or internet venders like Rockauto. All are readily available.
Old Dec 5, 2015 | 11:18 AM
Thanks for the help!!
Old Jan 3, 2016 | 08:38 PM
Kid Thunder's Avatar
Moog had 3 springs listed. One for stock front & 2 for a/c cars. One was a more heavy duty spring & the other it was lost between the heavy & stock. I took the lighter of the a/c springs & they worked great. OldCutlass(Eric said he used the heavey modle & i raised his car a lot. The middle raised about an inch & look just right for a stock car.
Old Jan 4, 2016 | 04:00 AM
We need pictures for the before and after stance. post the part number of the springs you used so others can see the results.
Old Jan 4, 2016 | 06:53 AM
The suspension is the same as on a Chevelle. There are a bazillion options ranging from stock rebuild to full aftermarket frames. Your goals and your wallet are the only limits.
Old Jan 5, 2016 | 12:02 PM
Sorry, I just reread the post & it was asking about springs for a 69 442. Mine is a 67 Cutlass. My mistake. But I do have part # for front springs for the 67. Sorry no pictures.
Moog lists 3 front springs. 5234 load 2025lbs. 5244 load 2124lbs, 5272 load 2279lbs.
5244 & 5272 are both listed for a/c cars. I used the 5244 & it brought the front up just right. Obviously not much use without pictures.
Old Jan 5, 2016 | 02:45 PM
Originally Posted by Kid Thunder
Obviously not much use without pictures...
I agree
Old Jan 5, 2016 | 04:28 PM
Seconded. The only way to go. Has the added benefit of protecting your investment by keeping the car closer to factory.
Old Jan 6, 2016 | 01:27 PM
69455's Avatar
Just more info
Detroit Speed makes several suspension kits pending budget / needs
http://www.detroitspeed.com/
Love my drop spindle coil over dbl adjustable Speed kit 3 front and back.
Old Jan 6, 2016 | 01:44 PM
69455's Avatar
Detroit Speed Stance
Old Jan 7, 2016 | 11:09 AM
BackInTheGame's Avatar
Schweet!
Browns are not normally on my palette, but that is one schweet looking ride, Mr. 69455!
wisniows
Nov 29, 2014 07:19 AM
RandyS
Jun 10, 2013 09:35 PM
real57vetteguy
Sep 9, 2012 08:10 PM
miked
Suspension & Handling
21
Jan 20, 2012 11:18 AM
44deuce
Aug 3, 2010 02:30 AM
