Steering Wheel
Old Jul 27, 2024 | 04:59 PM
Gary's 2 442-S's Avatar
Gary
Steering Wheel
I had my steering gear box restored. Once I got it back and installed it my steering wheel is misaligned. Any thing I can do to correct this?
Old Jul 28, 2024 | 05:12 AM
The problem isn't the steering wheel, it's the column clocking. The hub only goes on the column one way. You need to figure out where the column is misaligned. Start by jacking up the front wheels. Count the turns from lock-to-lock, then come back half way. If the front wheels are not straight ahead, the alignment was done incorrectly. You have to shorten and lengthen the two tie rods by an equal amount to center the wheels. Also, with the box centered, the scribe mark on the end of the steering shaft under the horn button should be at the 10 o'clock position. If not, the steering shaft has been installed incorrectly and needs to be corrected. The OEM steering parts only go together one way, using different sized fasteners on the rag joint and keying on the shaft parts. Aftermarket stuff doesn't always have these features.
Note the scribe mark on the end of the shaft.
Old Jul 28, 2024 | 06:51 AM
Gary
Thanks Joe.
I kind of thought that I just might have to make some adjustments to the tie rods but I was just not sure. The only thing that changed was the rebuilding of the steering box because prior to it being rebuilt the steering wheel was centered correctly
Old Jul 28, 2024 | 09:34 AM
Originally Posted by Gary's 2 442-S
Thanks Joe.
The pitman arm can go on the shaft in one of four orientations. Sounds like you have it 90 degrees off. It would have helped to know this up front, by the way. Your original post implied that all you did was have the wheel redone.
Old Jul 28, 2024 | 11:10 AM
Gary
I will pull the pitman arm and try to align it from there. I sent the steering box rebuilder the pitman arm attached so I gues he just did not align it corrretly. I appreciate your response
Old Jul 28, 2024 | 12:45 PM
Once again, before you unbolt anything, center the steering box by turning the wheel halfway from one lock. See where you are then and adjust or correct what is wrong. I'm just speculating, since I can't look at the car in person.
Old Jul 31, 2024 | 11:02 AM
Upstate 442's Avatar
10 o'clock or 12 o'clock?
I was of the belief that the scribe mark was supposed to be pointed at 12 o'clock. Which is correct?
Old Jul 31, 2024 | 11:26 AM
Sorry, typo on my part. 12 o'clock is the correct location.
Old Jul 31, 2024 | 09:27 PM
No problem. Thanks for the clarification!
pvossn66
Oct 16, 2023 03:39 PM
hystat
Suspension & Handling
Jun 15, 2021 01:40 PM
kbdecatur
Nov 20, 2012 04:57 AM
RAMBOW
Mar 7, 2011 03:18 PM
<Stanishj>
Nov 26, 2004 04:33 PM
