Steering Column Bushings
Old Sep 24, 2021 | 09:13 PM
Phoenix8990's Avatar
I have a 69 Cutlass with a tilt steering wheel. There is movement in the column up at the wheel. When I look into bearings for it I only see ones for non-tilt columns. Is it different from the tilt bearing? The CSM pictures look the same but don't give enough info to know if they are the same. I spoke with Parts Place and they didn't know and I don't see it shown in any other catalogs.
thanks,
Steve
Old Sep 25, 2021 | 06:48 AM
Are you sure it's a bearing? These tilt columns have a well-documented issue where the bolts holding the housing together come loose, causing motion as you described. See this website for how to access and tighten these bolts.
Old Sep 25, 2021 | 12:00 PM
No, I'm not sure it is a bearing. I guess it is just the race and the seat. WOW, thank you, I have had the wheel off and the dash out so many times I guess one more to get rid of the wobble will be worth it. I'll be replacing the lower bearing as well at the same time. But now I wonder if it only needs to be greased.
thanks,
Steve
bjfox1970
Mar 1, 2021 08:16 PM
1971 cutlasssupreme
Jul 23, 2018 11:17 AM
W-27
May 15, 2015 08:08 PM
bobkat2
Aug 21, 2013 06:24 AM
68conv455
Nov 19, 2011 07:36 AM
