Steering Column
Old Mar 29, 2026 | 06:40 AM
tbozant's Avatar
Steering Column
Looking for steering column for 1968 Cutlass S. Would like tilt steering. I have a floor shift (automatic). Aftermarket would be fine, just not sure what to look for. Thanks.
Old Mar 29, 2026 | 07:00 AM
Nearly all of the aftermarket columns take the larger 1969-up steering wheel hubs. If you want to retain the stock wheel, you need a 1967-68 column.
Old Mar 29, 2026 | 07:21 AM
tbozant's Avatar
My original steering wheel is junk. I will have to use an aftermarket wheel. Not sure of the length of the steering column.
Old Mar 29, 2026 | 07:42 AM
70sgeek's Avatar
'72 Cutlass ragtop
Chevelle OEM floor shift automatic columns may be the same as yours and if they are, you can search the web for Chevelle replacements such as
https://www.ss396.com/chevelle/INT-6...id=23011120941
https://www.ss396.com/chevelle/TILT-...id=23011120941
NPD (National Parts Depot) may also have remans for it (just as pricey though)...
Old Mar 29, 2026 | 11:52 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
See my post #5 in this thread.
https://classicoldsmobile.com/forums...column-190744/
Old Mar 30, 2026 | 03:56 AM
JohnnyBs68S's Avatar
This is probably the route I'll be going. I doubt I'll find a used factory column for le$$. I want to keep my big N34 wheel that is still in great shape.
Old Mar 30, 2026 | 07:58 AM
Read the specs carefully.
Old Mar 30, 2026 | 09:35 AM
Ya they don't collapse. The column I ordered was for a 68 no ignition switch floor shift car...C3 Vette.
I look at that as the wheel will kill you if the impact is that hard, regardless of the collapsible column.
Might as well go out in a blaze of glory vs being stuck in this country's horrible long-term health care system uh...options that WILL bleed you out quicker than a poke from the column.
You will need the aluminum hub adaptor for the faux wood wheel.
I called them to make sure I got exactly what was needed. I did have to monkey with the horn contact, but very minor.
I think it needed better insulation to avoid activating the horn circuit.
Old Mar 31, 2026 | 05:25 AM
Thanks for pointing that out, Joe. Is this why this listing for this column mentions only Chevy and Pontiac applications (although it does list a '68 442 buried deep in its applications list)? I'm not at all surprised the description and applications lists are inconsistent and incorrect, I'm currently dealing with a similar situation with a trailer light harness for our Genesis.
Roger60
Aug 22, 2024 07:42 AM
Gary's 2 442-S
Dec 29, 2021 12:41 PM
OCS72
May 23, 2021 10:09 AM
Fabian Olalde
Jan 25, 2016 10:11 AM
webby
Nov 30, 2012 06:52 AM
