SouthSide Machine Bars & Airbags
Or do you mean to what pressure are they inflated ? Start with 5 PSI in each bag. Add a couple pounds air pressure to the side producing the blackest tire marks.
This was my procedure for air bags. I also had SSM bars on my 70 Cutlass. 5psi on the drivers side. The passenger side depends on your burnout. Start with 5psi in the passenger side. I used to do a burnout in the bleach box and see which way the car wants to slide. (99% of the time it will slide right) If it drifted to the right (passenger side) while doing the burnout you need more air in the passenger bag. We're talking a pound or two at a time until it no longer wants to slide left or right in the box. Once it comes out straight you're done. I think mine ended up around 8-12psi in the right bag. Don't go over 15psi
