Shock/Spring Setup
Old Jan 8, 2013 | 07:36 PM
sklbndt's Avatar
Shock/Spring Setup
Have Fiiinnnaaaalllly begun work on my car. It is a 68 cutlass convertible with a 455 and TH400. Non A/C. In regards to suspension, since the car would have originally come with a 350, I'm not sure what sort of shock and spring setup I should run to obtain original ride height. Any ideas?
Additionally, I didn't realize until we took the body off the frame that it has air shocks in the rear. I noticed in the service manual where it mentions adjustable shocks but I didn't see any specific reference to "air" shocks. Could this have been a factory installation? If so, how can I tell? Any advantages/disadvantages to air shocks?
Thanks in advance!!
Old Jan 9, 2013 | 06:18 AM
Thanks in advance!!
Air shocks were a factory option but also a popular aftermarket addition at the time. Even the factory offered a Delco aftermarket air shock kit. The advantage of air shocks is that you can run your N50-15 tires and have them stick waaaaay out from the fenderwells without rubbing. The disadvantage is the bulls eye painted on your gas tank in a rear end collision.
Seriously, air shocks are only needed if you carry heavy loads or tow a trailer with significant tongue weight. Otherwise, I wouldn't run them. Frankly, if you do need suspension adjustability, use air bags that go inside the rear springs. The shock mount points really aren't designed for the extra load of air shocks. I've cracked the frame on a Cutlass at the shock mount by using air shocks on a car that I was towing with.
Old Jan 9, 2013 | 09:51 AM
I'm with Joe, I hate airshocks. They leak, and the overall ride just plain sux. The stance and your ride charactoristics will dictate your spring and shock setup. What are you after?
Old Jan 9, 2013 | 02:23 PM
sklbndt's Avatar
I kinda figured the load/hauling thing was what they would be all about. Won't be an issue with me as I have no intention of any of that so I'm gonna change them out for standard style shocks.
Am looking to obtain original ride height along with the best possible feeling ride and handling.
johnnyjaws
Feb 23, 2015 04:30 PM
1BOSS83
Jul 22, 2013 09:12 AM
jb70w30
Suspension & Handling
17
Aug 29, 2012 06:31 PM
cig1ar
Jun 30, 2009 12:59 PM
Longhorncutlass
Mar 2, 2009 01:53 PM
