Rally suspension?
Old Jan 30, 2010 | 09:09 PM
nukesec1's Avatar
Rally suspension?
Did the Cutlass Supreme in '73 have a Rally Suspension as an option? Not to believe everything I read on the net, but I saw someone post and claim on a site that thier '73 Cutlass Cupreme that they had purchased new had a 455 with "Rally Suspension". Any truth to that?
Old Jan 30, 2010 | 09:31 PM
Good question. I don't have much experience with 73-77s but if you could get a 455/400 and the Hurst package on those cars, I would expect them to have the FE2 suspension for handling. Doesn't sound too far fetched to me. I've seen much later models of Cutlass offer the rallye suspension handling packge, so it seems plausible. You'll have to take it a step farther to the Olds Mythbusters .......
Old Jan 31, 2010 | 09:13 AM
Yes, the FE2 suspension package was an available option and was included with the 442 package.
Old Jan 31, 2010 | 01:26 PM
nukesec1's Avatar
What does the FE2 suspension package consist of?
Old Jan 31, 2010 | 01:43 PM
2blu442's Avatar
Rats! One thing is a rear sway bar that I just sold last week
I know the 1970-72 FE2 suspension was different springs (shorter & stiffer?) a rear sway bar, and I believe a slightly larger diameter front sway bar. I would suspect, but don't know for sure that the 1973-77 was similar in differences.
Any 1973-77 Cutlasss/442 or the Chev, Buick, Pont models that were built on the same platform would have these items. Years ago I had a 1977 Delta 88 pace car and am pretty sure it had the same rear bar. John
Old Jan 31, 2010 | 08:11 PM
Far as I know, it is boxed control arms, axle braces, HD shocks and springs, 1" front and rear sway bars.
The sway bars on the 73=77 models are different from the 68-72 models, so make sure you get the right one.
Old Jan 31, 2010 | 09:14 PM
It's interesting to know that GM still uses those same codes for suspensions on todays cars, for example: the Caddy CTS has FE1, FE2, and FE3 as choices for it's ride and handling options.
Old Feb 1, 2010 | 12:51 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I don't know specifically about '73 A-bodies, but generally speaking FE2 "Rallye Suspension" was a ride-and-handling package as opposed to F41, which was a heavy-duty suspension option. While FE2 was included with the performance packages, either option was usually available seperately.
costpenn
Dec 28, 2013 08:39 AM
Oldsmofjord
Jul 23, 2007 05:24 AM
nohn
May 20, 2007 12:33 PM
mattnsac
Mar 26, 2007 06:15 PM
Jetstarjockey
May 18, 2006 01:40 PM
