Rag joint installation..66 442
Rag joint installation...66 442
Is there a trick to getting the rag joint clamp to slide onto the steering gear shaft? I fiddled around with it this afternoon and I could not get it started on the shaft.
There is an area on the rag joint that has no splines. This area must mate up with the flat (splineless) area on the steering gear shaft.
