Rag joint installation..66 442
Old Oct 2, 2012 | 05:36 PM
bobfo1's Avatar
I'm putting a new rag joint on my 66 442. Does the opening for the clamp fit over the flat spot on the steering gear shaft?
Old Oct 2, 2012 | 09:11 PM
Nufo's Avatar
yes... i just put mine on yesterday... also '66 442
Old Oct 3, 2012 | 11:59 AM
Run to Rund's Avatar
The thru bolt goes into that recess.
Old Oct 3, 2012 | 02:09 PM
bobfo1's Avatar
Rag joint installation...66 442
Is there a trick to getting the rag joint clamp to slide onto the steering gear shaft? I fiddled around with it this afternoon and I could not get it started on the shaft.
Old Oct 3, 2012 | 02:42 PM
Nilsson's Avatar
There is an area on the rag joint that has no splines. This area must mate up with the flat (splineless) area on the steering gear shaft.
Old Oct 3, 2012 | 03:00 PM
RandyS's Avatar
I won't slide on unless you remove the bolt. Sometimes you can open up the clamp a bit with a flat blade screwdriver and it will slide on easier.
DRXOLDS
Sep 10, 2014 08:40 PM
71 Cutlass
Mar 16, 2013 07:28 PM
MDchanic
Suspension & Handling
May 22, 2011 09:21 AM
STLCRZY
Apr 26, 2011 11:21 AM
J-(Chicago)
Aug 22, 2009 09:25 PM
