Rack & Pinion Conversion
Old January 26th, 2015, 07:43 AM
Wedgewood Rod Shop's Avatar
So, this is going to be a crazy question, but has anyone had any experience with a rack & pinion conversion on a 60s big body? Starfire, Ninety-Eight, etc?
I have a 1964 Ninety Eight that I am considering converting to a rack to support a big motor and exhaust. Any thoughts or suggestions would be greatly appreciated.
Wedgewood Rod Shop is offline
Old January 27th, 2015, 07:56 AM
The 1963-64 cars are different from the 1965-70 cars, and Chevy parts don't work. This will be a completely custom installation and will require careful selection of the rack inner pivot width and placement to avoid bump steer. Personally I think this will be several thousand dollars for very little gain. I'd get the stock box rebuilt with a quick ratio gear set and call it good.
joe_padavano is offline
Old January 27th, 2015, 05:06 PM
Thanks, I appreciate the info. I can't use the stock box due to space and am hoping to eliminate it. I plan to do the work myself, just looking for any guidance as to a particular rack someone has used on their project.
Old January 28th, 2015, 08:21 AM
I strongly suggest you read these articles:
http://www.crankshaftcoalition.com/w...inion_steering
http://www.longacreracing.com/techni...aspx?item=8162
http://www.hotrod.com/how-to/chassis...eer-explained/
http://www.panteraplace.com/page135.htm
zgzmithr
February 26th, 2015 07:36 PM
mrolds88
Suspension & Handling
May 26th, 2014 07:38 PM
billmerbach
November 12th, 2013 08:27 PM
noeatnosleep
July 2nd, 2011 12:30 PM
88fan
April 23rd, 2010 04:55 AM
Quick Reply: Rack & Pinion Conversion
