Preferences on rear trailing arms
Old March 23rd, 2013, 12:40 PM
68vaolds's Avatar
I'm going to be replacing the rear upper and lower trailing arms on my 68 Cutlass S and was wondering which supplier is better and has a better cost.
68vaolds is offline
Old March 23rd, 2013, 05:07 PM
If your going to replace just the bushings for a stock application, I would suggest using moog parts through your local parts house, or rockauto. That would be the most economical route.
oldcutlass is offline
Old March 23rd, 2013, 05:38 PM
68vaolds's Avatar
I was actually thinking about replacing with either QA1 or UMI over stock.
68vaolds is offline
Old March 24th, 2013, 07:10 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I have the spohn arms, however I can't write a rave review about them, because the center adjustable rod is too short in my opinion. The ends are nice, but I didn't like the center piece.
J-(Chicago) is offline
Old March 24th, 2013, 09:22 AM
As a structural engineer, I can tell you that putting the adjuster in the center is the absolute WORST possible thing you can do. That's where bending loads are greatest, so the last thing you want to do is to put an adjustment screw there that's smaller in diameter than the rest of the arm. The screw is now the most compliant part of the arm and it pretty much negates any stiffness benefit from the rest of the arm. Note that most arms or linkage rods that are weight optimized for stiffness have a WIDER center section and then narrow down at the ends where the adjuster is located.
joe_padavano is offline
Niko
September 15th, 2014 01:43 PM
HonestDave
March 31st, 2012 06:33 PM
leepear
February 13th, 2012 04:21 PM
oldzy
July 4th, 2010 07:53 PM
Quick Reply: Preferences on rear trailing arms
