Power Steering gear box
Old Dec 7, 2012 | 12:30 PM
foo's Avatar
foo
Its been sitting for long time should I just clean it up and call it a day or
Should I send it out to get rebuilt or could I attempt to do it myself?
Old Dec 7, 2012 | 01:46 PM
Was it good when it was set aside? If so, I don't think a rebuild would be necessary.
Old Dec 7, 2012 | 01:53 PM
foo's Avatar
foo
I think it was, no leaks from what i could tell just sitting there. (I have not seen it under load though) looks like it need some cleaning up
Old Dec 7, 2012 | 01:55 PM
How many miles on the car? If it's not broken maybe just leave it alone. Only thing to really look at is the connections on the PS pump and the gearbox. If there's any leakage or the hoses look questionable, worth replacing them. ILT sells the correct set for 65.00 if you need new ones.
Gearboxes can be rebuilt but you need some special tools. There's a very good write up in the 72 CSM on this if you want to look at rebuilding either the PS pump or gearbox. I'd consider changing the fluid if nothing else - you can replace it with Dexron III (even recommended in the owners manual). Taking off the gearbox requires you to disconnect the intermediate steering shaft, center link from the pitman arm, and undo 3 bolts holding the assembly to the frame. Helps if you already have the PS pump off the block first. Lots of work to really clean it up nice.
Old Dec 7, 2012 | 02:01 PM
foo's Avatar
foo
76,000 miles could be more if the odometer is past the 100,000 mark im sure you looked at what I got going in the major build section allan everything is torn down and out of the car
Old Dec 7, 2012 | 02:16 PM
Hmmm after looking at your thread, it's a tuff call there. I'd clean it up and paint it, you can always change it out later.
But I'm a cheap SOB, lol, I only spend money when I need to.
Old Dec 7, 2012 | 02:51 PM
jfb's Avatar
jfb
I would at least get a seal kit for it these can be a real hassle after shrinkage. The seal is real easy to replace when the pitman arm is off and get a manual also if you do not have one.
Old Dec 7, 2012 | 04:49 PM
foo's Avatar
foo
are you talking about all seals or just the one?
Old Dec 7, 2012 | 04:50 PM
foo's Avatar
foo
lol I was thinking about doing that, try to save some money for now
Old Dec 7, 2012 | 05:07 PM
You can wear these boxes out, but you really can't kill them.
If it's really only got 76K on it, just reinstall it and use it.
If you want a tighter ratio, the Jeep GC swap is a good bet.
scharpp
Jan 19, 2015 10:37 AM
c-towndave
Apr 14, 2014 07:38 PM
4speed455
May 13, 2013 10:52 AM
morexfiles
Apr 22, 2013 12:51 PM
nohn
Jul 7, 2008 11:55 PM
