Polyurethane bushings for upper control arms
My upper control arm bushings went south so I had some polyurethane bushings installed. I’m really not liking the stiffness and the ride height. It actually lifted it up. It’s so stiff it’s like a low rider. Has anyone else had this problem? 72 convertible cutlass. I have 15x8 wheels on it now.
I have polyurethanes in my upper and lower, front and rear control arms. I feel like changing it back to rubber because it rides very hard. It feels like my tires are made out of stone. The potholes in NYC is not making it any easier for me.
Upper control arm
Did you tighten up the control bushings up in the air or on the floor?
If you torqued them down in the air as you state that was a mistake. They need to be torqued with the weight of the car on the suspension. I have poly in my 68 vert and love the ride, not harsh at all and handling is much improved.
It is very rare that I hear of someone that likes the polyurethane bushings. You for sure need to loosen them and re-torque them with the weight of the car on them before fully deciding you don't like them.
For the windy roads I like to drive my 10 on here in south central KY....the poly works great.
www.somernitescruise.com
Is there a specific way that it needs to be done? Or do is loosen them all up and see what happens?
I've been driving on poly in my 69 and 68 Cutlass for over 20 years, I'll never go back to rubber. I also used poly when I installed the heavy sway bar in front and rear. My next step is putting stiffer 1 inch drop springs.
You will like the 1" drop, mine are from BMR, I love the ride ,I won't use rubber again either.
When you tightened them down with the car in the air it clamped them in that position. All you need to do is loosen all of them and AFTER all of them are loose, tighten them back up with the cars weight on them. Don't just loosen and tighten them one by one or it will have nearly no affect.
Any shims should be for alignment. After changing the bushings it is a good idea to get it aligned. No need to loosen that part, only the large nuts on the bushings and the lower control arm bushings.
RUBBER bushings need to be torqued with the suspension at normal ride-height. Poly bushings DO NOT need to be torqued at ride-height. They're not bonded like rubber bushings, the suspension can be torqued in ANY position.
If the control arms are stiff moving up and down after installing Poly bushings, THEY WERE INSTALLED WRONG. First Guess: Control arms were bent during installation of the bushings. If the ride height changed, it's likely the springs weren't installed properly.
ABSOLUTELY NOT.
I won't use rubber if I can source Poly bushings.
Read the instructions that come with the poly kit, clearly states to torque with weight of car on the suspension.
The instructions may say that, but I found it is not required, at least not on the rear control arm bushings that I installed. If you look at the way the bushings are manufactured, you will see what Schurkey said above.
The factory bushings have the rubber bonded to both the outer shell and the inner sleeve, and the inner sleeve is slightly longer than the bushing so that it is pinched between the control arm mounting ears. This means there is a limited arc of movement as the rubber can "stretch" only so far, and therefore the bolts need to be tightened with the suspension loaded so that the arc of movement is centered.
The poly bushings that I used are made differently, with a polyurethane insert pressed into the outer shell, then the inner sleeve is pressed into the poly bushing. This allows the inner sleeve to rotate 360º instead of having a limited arc of movement, which means the bolts can be tightened without having the suspension loaded.
Perhaps some poly bushings are manufactured differently? I don't know as the only ones I have experience with are the PST rear bushings.
edit:
The Energy Suspension installation instructions don't mention anything about having the car at normal ride height when installing front busings:
https://www.energysuspensionparts.co...sion/17019.pdf
edit:
- Re-torque to hardware to factory specifications.
The factory bushings have he rubber bonded to both the outer shell and the inner sleeve, and the inner sleeve is slightly longer than the bushing so that it is pinched between the control arm mounting ears. This means there is a limited arc of movement as the rubber can "stretch" only so far, and therefore the bolts need to be tightened with the suspension loaded so that the arc of movement is centered.
BONDED (rubber) bushings have to be torqued at ride-height. The rubber needs to be in a "neutral" position, because as the control arm goes up and down, the rubber is stretched clockwise and counter-clockwise. If you torque the suspension with the control arms fully "down", the rubber never flexes in one direction, but flexes twice as far the other way. It will spend almost it's entire life stretched to near-maximum design limit in one direction, occasionally relaxed as the suspension arms drop, and wound-up to twice it's intended motion when the arms raise going over a bump, or leaning on corners. The bond between rubber and steel soon rips, and then the bushing is ruined.
NON-BONDED (Polyurethane, Del-Alum, etc.) can be torqued with the suspension at any position. The Poly doesn't twist, the steel sleeve just rotates within the bushing insert--which is why they tell you to grease the thing during installation. It's one of several reasons that Poly bushings are easier for a D-I-Y to install than rubber.
