New front springs
Old May 20, 2022 | 06:03 PM
71OldsCut's Avatar
New front springs
Hi,
This is related to a previous post, but it branched out into its own new issue so I thought I would make a new post to get a wider audience, lol.
Basically the issue is that I put new front springs (Moog 5390) in my 1971 Cutlass with a 350 engine. After the springs are properly seated in the top and bottom when I jack the control arm up it gets to about 2" from where I need it to bolt up the ball joint and it starts lifting the car. One solution mentioned, primarily used for cars with the engine out is to wrap a chain around the jack and upper control arm. It would probably work, but I was wondering if anyone else encountered this and what you did about it.
Old May 21, 2022 | 04:54 AM
cdrod's Avatar
Rodney
Without the weight of the engine, the front will lift. You will need to use a spring compressor to finish the job.
Old May 21, 2022 | 06:29 AM
71OldsCut's Avatar
That's the strange part, it still has the engine in, lol. I was just wondering if others have encountered this with the engine in or if something else is going on here.
Old May 21, 2022 | 06:59 AM
cdrod's Avatar
Rodney
Which springs are you installing? Are they Moog, Do you have part number?
Rodney
Old May 21, 2022 | 07:06 AM
71OldsCut's Avatar
Correct, they are Moog, 5390. I thought maybe I had 455 springs or something but they appear to be right for stock replacements.
Old May 21, 2022 | 11:04 AM
cdrod's Avatar
Rodney
Are you jacking the LCA at the ball joint or under the spring pocket? The LCA has a 2:1 motion ratio; so you'll get twice the leverage if you jack at the ball joint location instead of near the spring pocket.
Rodney
Old May 21, 2022 | 11:41 AM
71OldsCut's Avatar
Thanks! I was wondering if that would make a difference. I am currently under the spring pocket. Will give that a try
Old May 21, 2022 | 12:26 PM
71OldsCut's Avatar
It worked! Thanks for the help. Now just have to do the drivers side and the rest should be easy.
oldsmoboogie
May 5, 2020 09:42 PM
kitfoxdave
Suspension & Handling
Sep 22, 2012 07:30 AM
oldzzy
Sep 6, 2010 03:38 PM
ELECMAN
Apr 15, 2010 11:34 AM
mcutlass1969
Aug 6, 2006 03:47 AM
