My setup
Old Jun 25, 2009 | 04:11 PM
gearheads78's Avatar
car guy
My setup
A lot of people have asked me for details of my suspension. I have always been a street strip straight line guy so about 2 years ago I started researching A-body suspension.
I don't deserve any credit for what I did. I just coppied what has worked for others. Lots of guys on Chevelles.com are using the same setup and having good results. The hardest part was getting what I wanted and not going overkill. Just like bigger is not always better for cam shafts and carburators it also applies to suspension parts , springs, and sway bars.
In my mind I wanted a car that drives like a modern sports sedan. I'm not going to run the cones every weekend but if I have to dodge a ladder in the middle of the highway I wanted to do so without scaping the door handles on the pavment.
The best thing I did was make a call to Marcus at SC&C based on many many recomendations.
http://www.scandc.com/faqs.htm
I told him what I wanted out of my car. He told me what I needed on several occasions even down selling me or telling me to buy something someone else carried because it would fit my needs better even though he carried a competing product. I followed all his suggestions and ended up with a car that is even more than my expectations.
springs- Eibach front was perfect for the low height I wanted but had to cut about 1/2 coil
in back and will probably cut another 1/4 coil for perfection
shocks- Bilstein hot rod shocks sold by OPG same as thier other shocks but painted black with black boots instead oof yellow with blue boots
front upper control arms and ball joints- stage II + kit consists of Howe tall ball joints and SPC fully adjustable upper control arms
steering box - Lee custom 12.7:1 bluprinted box 670 series (drives like a rack)
front bar- stock bar from a 66 GTO with rubber bushings and urethane end links
rear bar- OPG 1" aftermarket bar
rear control arms- Currietrac upper and lower arms with johnny joints. Allows full articulation with no binding
rear axle bushings- stock replacement rubber
Old Jun 25, 2009 | 04:43 PM
BerBer5985's Avatar
Did you also replace the rest of the front suspension like the tie rods and tie rod ends center steering arm or whatever that thing is called? I want to do something very similar to your setup without going overboard, but I also want to make sure the rest of the parts get replaced as well since I'm going to have it all apart.
Last edited by BerBer5985; Jun 25, 2009 at 04:44 PM. Reason: Needed to add something
Old Jun 25, 2009 | 04:46 PM
BerBer5985's Avatar
Oh, and I'm sorry but one more question for you....I want to do disc brake upgrades on all 4 corners and maybe try the 2" drop spindles with the package they offer. Would that be a good route to go for lowering the vehicle, or would getting stock spindles and then lowering springs be the best route or a combination of both?
Old Jun 25, 2009 | 05:44 PM
car guy
If you want to use my setup do not use dropped spindles. The springs and the tall ball joints will take care of the height. What size wheels are you wanting to run? That will determine what brakes for me to suggest.
Old Jun 25, 2009 | 05:51 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Hey Richard, any 60' times with the new setup yet? I'm curious how she sticks.
Old Jun 25, 2009 | 06:02 PM
BerBer5985's Avatar
I'm going to stick with stock 15"x8" all around. So I guess just the normal size brakes.
Old Jun 26, 2009 | 03:27 AM
Thanks Richard
Very good information
Old Jun 26, 2009 | 11:19 PM
mugzilla's Avatar
is Fast Enough ...
I have '70 442 w/ disc brakes...
Do I run my spindle with the tall ball joints ..?
Old Jun 27, 2009 | 07:19 AM
car guy
Disk brake spindles are fine but I an not sure if 15" wheels will work or not. I would put a call in to Mark. He is sometimes hard to get ahold of but persistance is well worth it. Set aside at least 30 min to talk to him though. There are no short conversiontions with him.
Old Jun 27, 2009 | 07:23 AM
car guy
Would not want to get embarrasted off the track. After what I have had in the past 8.0's feel slow. I bet this car would be luck it run in the 11's in the 1/8th
OldsMotion
Brakes/Hydraulic Systems
Jul 12, 2007 12:45 PM
Kennybill
May 10, 2007 12:52 PM
snowri
Mar 29, 2006 04:36 AM
Kennybill
Jan 12, 2006 05:31 AM
anthonysteve38
Dec 11, 2004 11:47 AM
