Moog Single Rate vs Variable Rate ("CC") Springs
The darned car is dragging its butt again, like a dog with worms
I'd replaced the original springs with a used set from a 98, then a year later I installed 1" boosters, and now she's sittin' low again, so I guess its time for a new pair.
I was wondering what experience others have had with the Moog "standard" single-rate springs versus their variable-rate "CC" series (I assume that means "Cargo Coil").
The car's got swaybars front and rear, so it's not a floater, but I don't want to feel like I'm driving a hardtail either.
For my application, Moog lists the spring rates as 132 lb/in vs 236 lb/in, so the difference is not small.
ASSuming that my current springs are somewhere between 75 and 100 lb/in, and knowing that they don't feel TOO soft, I'm leaning toward the "regular" springs
What do you think?
Thanks!
What do you think?
Thanks!
Eric,
I hope this can be of some help in your decision.
Initially I had the original springs and shocks in the rear of my 76 when purchased.
The rear sat a little lower than the front after new springs and shocks were installed in the front.
I tried 3 different combinations before settling on the height I wanted in the rear.
The regular rear springs didn't seem to do the trick, I then added air shocks and with 50psi I was able to achieve a height I could play with up or down.
The air shocks only lasted 3 years, at that time I put in the "CC" coils. They call them comfort coils here.
Tighter coils in the top of the spring for comfort, not sure if this is the cargo coil you speak of.
They did put the rear at a little more than stock height with a decent ride along with new Gabriel gas shocks.
The rear didn't take long to settle and ride height was again a little lower than the front.
I then switched to 76 vista cruiser wagon coils, it put the car up 2 1/2 inches in the rear , a firmer ride for sure.
I'm still running the wagon coils along with the Gabriel gas shocks, I like the rear sitting up that bit higher now.
Hope this helps
Cheers
Eric
Hope this helps
Cheers
Eric
Wife would have definitely made me put the cheerleaders in the trunk.
Heck, a few weeks ago, she barely let me put a stripper, who had just crashed her car, in the back seat -- and she wasn't even cute.
Eric,
Hope this helps
Cheers
Eric
Hope this helps
Cheers
Eric
Ron,
I'm not familiar with Cargo coils, I used the comfort coils which has tighter wound coils at the top of the spring. The regular coils are not wound tight at the top, this is the only way I can describe them differently . The shocks I used were also listed under the vista cruiser wagon.
They did push the rear up 2 1/2 inches above the rear tire on my 76. I'm now running 255 60/15.
Hope this helps
Eric
Hope this helps
Eric
Okay, I installed the Moog CC613 rear springs in the '73 Delta Convertible.
The ride height looks exactly where Olds would have wanted it (I had actually hoped for just a bit higher than that), and the ride is smooth, and just a little bit tighter than it was with the 98 springs (or the 88 springs before them).
Overall I like them.
If in a week or two I feel like I want it a bit higher, I can always re-install the 1" spacers I had in there before.
Interestingly, I had had to fight the 98 springs in when I installed them, and I had to fight them out today, but the CCs, which have an extended height that's a couple of inches less than the stock springs, dropped right in with no prying, jumping, or cursing.
Thanks for the advice, Eric!
