lowering
Old Apr 6, 2011 | 01:48 PM
mattbeasty's Avatar
lowering
im doing a front disk conversion from master power brakes and was thinking of cutting the coil spring. im just wondering befor i do this has anybody else done this? if so how many coils is too much and how many did you take off?
Old Apr 6, 2011 | 01:56 PM
I've cut around 3/4 coil to one full coil off the front of A-body springs and I like the look of the rake. You can't simply cut the back springs since the end coils are reduced diameter. Cutting springs is easy. I've used two different methods, either a cutoff wheel or a torch. When using a torch, I submerge the spring in a bucket of water so the water level is just below the cut line. This precludes damaging the heat treat on the spring metal.
Old Apr 6, 2011 | 02:11 PM
mattbeasty's Avatar
sorry its for an A body and i was only wondering about the fron thanks for the advice do you have any pics?
Old Apr 6, 2011 | 06:44 PM
gearheads78's Avatar
car guy
When I first got my 66 I slapped some tires and wheels on it. It looked like a 4 x 4. I chopped the springs front and rear twice. I didn't want to go too far so I cut about 3/4 of a coil in front and 1/2 a coil in back. I drove it for a week to settle and it was better but still not the look I was after. I ended up taking about another 1/3 coil in the front and 1/4 coil in back to make it perfect. Here is stock height and after 2 coil cuts.
I drove it like that for 6 months and then pulled the body off the frame for a complete build. As mentioned above if you have pigtail top and bottom springs you can't cut the rears.
Old Apr 6, 2011 | 10:15 PM
mattbeasty's Avatar
oh okay now i know what he was talking about thanks a million and nice ride sits real pretty
#1CutlassSupreme
May 27, 2008 11:30 AM
mp71conv
Apr 29, 2008 01:51 PM
eddiem06
Dec 24, 2006 08:06 PM
lestat4speed
Sep 11, 2006 04:13 PM
SuperSickBoy
Jun 8, 2006 12:53 PM
