Leaking power steering gearbox
Old Jan 10, 2026 | 12:57 PM
72Ucode supreme's Avatar
I have a 1972 Cutlass Supreme 455 U code. Put it up for winter, noticed power steering fluid on the garage floor. The box is leaking from the seals, not sure where. I am going to replace the box with a quicker ratio unit. What brands are a good quality box with a factory setup using the same type of fittings? I know there are a lot of junk units out there. Any suggestions would be greatly appreciated.
Old Jan 10, 2026 | 01:00 PM
FYI, the lower shaft seal (if that is what is leaking) is extremely easy to replace.
Old Jan 10, 2026 | 01:43 PM
I figured while it was out to replace with a quick ratio for a tighter steering feel and reduce lock to lock from 4 1/2 to 2 1/2 . I'm just not sure of who makes a quality box?
Was looking at the Cardone 27-6509 it seems to fit the bill.
Old Jan 10, 2026 | 02:20 PM
OLDSter Ralph's Avatar
Check them out.
https://www.larescorp.com/
Old Jan 11, 2026 | 04:17 AM
cdrod's Avatar
Rodney
You could also take your box to a local rebuilder and have them convert it to a fixed 12.7:1 ratio.
Rodney
Old Jan 11, 2026 | 01:56 PM
Thanks will look it up..
Old Jan 11, 2026 | 01:57 PM
Checked near me could not find anyone who does that. Thanks anyways..
Old Jan 11, 2026 | 02:01 PM
I completely understand wanting the quick ratio box, but wanted to let you know the box doesn’t need to come out to replace the lower seal.
Old Jan 11, 2026 | 02:34 PM
I will look at box and see where it is leaking from. If I can stop the leak without removing box that would be great. i will let you know when I find source of leak. Thanks for the info..
Old Jan 11, 2026 | 02:39 PM
i never replaced a power steering gear box. So took a class at You Tube university, looks pretty straight forward as long as the gearbox is centered before install and stays that way.
Old Jan 11, 2026 | 05:11 PM
70sgeek's Avatar
'72 Cutlass ragtop
Look up Carhex (I think his full name is Hector Carillo) on this or the V8 Buick website - he rebuilds the Saginaw boxes to fast ratio firm feel specs for reasonable $$.
Borgeson and CPP make essentially all new Saginaw boxes, also firm feel/fast ratio - CPP is its own site, Borgeson can be found on Summit, Jegs, etc.
if you want the best, Lee Power Steering is probably the top choice, awesome but pricey. -
Consider however with any firm feel upgrade, you arguably should replace your pump with a higher PSI / higher flow than stock specs. Otherwise the firm feel box might be under powered and somewhat lethargic to manage.
March Performance and Lee are two options for high performance pumps that work well with firm feel boxes.
Old Jan 11, 2026 | 10:11 PM
Thank you for the info.. I thought that replacing steering pump was going to be needed using a quick ratio unit from the research I did.
Old Jan 12, 2026 | 07:47 AM
70sgeek's Avatar
'72 Cutlass ragtop
Not so much if it were only a quick-ratio w/o the firm feel upgrade - it's the firm-feel setting that arguably requires the higher pump pressure/flow.
Also, a 2.5 L-to-L radius can be kinda twitchy on the street - a 3-3.25 turn radius is generally more comfortable for all around driving - still considered quick(er) ratio over stock but not oversensitive to every steering wheel input. If you have the budget, look at this box: https://leepowersteering.com/product...m-classic-cars
I have it on my ragtop and IMO it's the perfect box for general driving purposes - 3.25 turns L-to-L (I have an Olds 15" 4-spoke rally steering wheel) and moderately firm feel so not cumbersome at low speeds or idle.
If you do ultimately change a box out, also install new pressure and return hoses at that time.
Old Jan 12, 2026 | 10:13 AM
dc2x4drvr's Avatar
The Lee steering boxes are awesome, best modification I did on my car.
Old Jan 12, 2026 | 10:55 AM
I found the leak. It's coming from where the steering shaft goes into the box. Can you replace that seal without removing the gear box?
Old Jan 14, 2026 | 03:42 AM
Yes you can, I also have a leak at my pitman arm seal. I had my box rebuilt/ changed to fast ratio by Chips Power steering about 20 yrs ago. Since then my pitman seal leaks a little- enough to make a mess on floor when car is stored over winter. I sent it back to Chip and he replaced seal and it still leaks.
Old Jan 31, 2026 | 07:11 AM
I decided to just replace the leaking seal when it warms up a little more here in Michigan. I bought the seal kit and after taking a class at You Tube university looks pretty straight forward. Thanks for the info.
Old Feb 1, 2026 | 02:30 PM
Ontario69Hurst's Avatar
Which is the best Pitman shaft seal kit
I also have a leaky pitman shaft seal and I was looking at the Edelmann 7856 seal kit on Rock Auto. But before I waste my time I was just curious what the experts think about this kit. Should I be buying a different brand from RA or going to my local part store instead?
bluecutlassconvertable
Jul 7, 2025 12:26 PM
Roadie
Suspension & Handling
Nov 7, 2024 01:37 AM
ilikeolds
Oct 7, 2022 07:40 PM
Natedawg
Mar 27, 2020 09:11 PM
agtw31
15
Jun 14, 2010 06:01 AM
