In a jam with control arms....literally
Old Jun 15, 2019 | 03:53 PM
  #161
Glad it all finally got done, the next time will be easier...
Old Jun 15, 2019 | 04:07 PM
  #162
Macadoo's Avatar
The next time?!?
Old Jun 15, 2019 | 07:42 PM
  #163
72455's Avatar
1972 U code Supreme
Ahhh...the feeling of knowing that one more project is behind you😀...despite all the frustration and setbacks, nothing compares...
Old Jun 15, 2019 | 08:56 PM
  #164
Macadoo's Avatar
You got that right! And now maybe I can drive interstate without the white knuckles. I've gotten to the point where I know every nut and bolt in the car. I've done the Engine, exhaust, transmission, rear end, interior, engine again, a little body work and paint, rebuilt a few Quadrajets, gas tank rehab with new sending unit, painted ghost stripes on the hood, ....uhhh, I think that's about it. Oh! And front and rear suspension
Old Jun 15, 2019 | 09:26 PM
  #165
coppercutlass's Avatar
Chevy budget Olds powered
Mac you have done a hell of a job on your car.
Old Jun 15, 2019 | 09:28 PM
  #166
Originally Posted by Macadoo
The next time?!?
Yes. You'll be surprised how time flies and the things you fixed 20 years ago need fixing again.
Old Jun 15, 2019 | 09:51 PM
  #167
Macadoo's Avatar
Thanks Copper. You might have had something to do with it through the two or three hundred texts you answered for me
Okay, deal. If I'm alive in twenty years, I'll think about doing it again. Lol.
Old Jun 15, 2019 | 09:58 PM
  #168
Hey, I'm at that point with my car. A lot of the stuff I did back in 1990 needs to be done again - the seats need to be recovered, it needs new carpet due to fading in the sun, the convertible top needs to be replaced, and it needs some AC work. I did all of this before and I can't believe time has passed so quickly and it needs to be done again. Seems like it was just a few years ago.
Old Jun 16, 2019 | 04:23 PM
  #169
Macadoo's Avatar
Well if this is cyclical then I'd better start building a small block to replace the 455
Old Jun 16, 2019 | 05:13 PM
  #170
6 different engines in 13 years , 4 different gear swaps on the rear end, transmission #3 , 1 wreck , 2 full paint jobs 2 partials , 3 different front springs , 3 sets of front shocks , 5 different sets of rear shocks , the list goes LOL. I cant leave the car alone or stop changing stuff. I have only hurt 1 engine and had 1 wreck. all the other things where just thoughts I decided to pull the trigger on LOL . My active brain is a dangerous thing. I have only 400 miles on my new engine and im planning a 455 build. It never stops. Its a blessing and a curse.
Old Jun 16, 2019 | 05:15 PM
  #171
72455's Avatar
1972 U code Supreme
What size tires are you running?
Old Jun 16, 2019 | 06:53 PM
  #172
1948 Indian Chief?
Old Jun 17, 2019 | 05:25 AM
  #173
Macadoo's Avatar
You? A 455? That's awesome! You're going to tear up the track! If you go .030 over, I have the piston ring compressor / installer from Summit. 4.155" if memory serves.
235 60r15 in front, 275 60r15 in the rear. Makes it hard to carry a spare, lol.
1948 Indian Chief?
It's a Chief but I think it's a little earlier. I don't rightly remember. It's not mine. I wish it was!
Old Jun 17, 2019 | 05:52 AM
  #174
72442455's Avatar
Joe Ralph
Okay, so yeah, those bushings crushed okay. It was very very tight but it got there. And that driver's eyelet looks better too. Much easier tightening that with weight on the wheels. That gave me room to get a ratcheting combination wrench on there.
Header bolts are in. It was just one of those things. The garage that did my alignment got one of the back header bolts in for me but couldn't get the other. This morning I walked out there and it went right in, on the first try!
And today, just when I was finishing up, I had a front shock puke all over the floor. These were the KYB Gas-adjust shocks; not cheap and just a couple years old. But to be fair, I had to grind the mounting forks down a little to get them to fit inside the LCAs so I must have overheated them (even though I was dipping them in water every few seconds).
Anyway, I'm done. And now it's raining (of course) but maybe tomorrow I can test it out. It is Father's Day after all
Thanks for all the help with this project. It certainly wasn't my favorite of everything I've done to this car but at least it was successful and the car is now road-worthy.
Awesome! Looks great Mac! I’m just now reassembling my control arms hehe - have to detour to mini van brakes ughh - then clean up the frame and start tossing it back together - if it would just stop raining when I’m not working that would be great
Old Jun 17, 2019 | 07:16 AM
  #175
72455's Avatar
1972 U code Supreme
Welcome to my world ..lol
Old Jun 17, 2019 | 03:15 PM
  #176
Macadoo's Avatar
Thanks man. But I feel your pain; it won't stop raining here either. I think I've driven it all of about 5 miles since I got it done. And I need brakes on my truck but I need a few days off, lol. Let me know if you have any questions when you start assembling but really, my biggest problem was installing the springs in these tubulars with the soft (ish) spring pads in the lowers. I couldn't just pry the spring into the hole and had to use spring compressors. That and I had a shock puke its fluid all over the floor when I was finalizing the last step of the rebuild. Sigh....
You should have an easier time with the stock arms. And do you have ramps? It made torquing the LCA bolts a lot easier. More room for the wrench.
Old Jun 23, 2019 | 03:43 PM
  #177
72442455's Avatar
Joe Ralph
Thanks Mac - had a good day today - lots of painting done - I pulled out the new front springs that have been sitting in a box since 2002 (ish) - I noticed that the spring ends are round and not flat - didn’t you encounter the same situation? How did you handle it?
No ramps - but I think I can borrow some from a friend - good idea - can’t wait until I’m at the torquing it back together stage lol
Old Jun 24, 2019 | 06:22 AM
  #178
Macadoo's Avatar
Yeah man, I did have that problem with my springs, so I didn't use them. After fighting with Rockauto, they emailed me and said that I had ordered springs for a Canadian Cutlass. So I checked the listing and it didn't say a darn thing about them being Canadian, and I don't really think there is such a thing as Canadian springs. I ended up returning them and just rehabbed my old springs. Still not sure about that decision but they didn't sag when I took out the shocks and when all was said and done, I gained about a half-inch in height.
When I tried fitting those springs (that weren't flat on top) I never felt that I could get them located in the upper pocket correctly. Like, not at all!
Old Jun 24, 2019 | 06:35 AM
  #179
72442455's Avatar
Joe Ralph
Argh! - well I can’t return 18 year old springs ... maybe I’ll use my original as well - Time to do some reading up on it - thanks for the reply
Old Jan 23, 2022 | 01:22 PM
  #180
jarcher442's Avatar
I have used the method that is in my 67 shop manual for 40 yrs with no problem what so ever. Its safe with no fear of a loaded spring letting loose. I could never figure out why removing the spindle was the chosen method, I tried that once and it is scary as hell. I made up my own version of the tool that it recommends by using a 5/8 all thread with coupling nuts to prevent stripping threads. I have installed taller springs this way with no problems. By removing the inner bushing bolts the A arm just swings outward allowing the unloaded spring to be removed. Support the raised front end with jack stands, remove the shocks, insert tool down thru the shock mounting hole, compress spring slightly and remove inner bushing bolts and then unscrew the upper coupling nut relaxing the spring. remove tool and the unloaded spring can be removed. To install insert spring, slide tool down thru shock hole and lower control arm and start threading the upper coupling nut till the inner bushing holes line up. These holes can be tweaked with a floor jack under the a frame using very little pressure. once the bolts are installed remove the tool.
Gauchobyte
Suspension & Handling
Aug 9, 2017 02:53 PM
RustyOlds
Brakes/Hydraulic Systems
37
Mar 28, 2016 04:30 PM
Mhoward20
Jul 5, 2013 07:19 AM
Allan R
Nov 11, 2011 11:11 AM
Flye
15
Apr 13, 2010 09:14 PM
