I have a question...
Old Jun 10, 2015 | 07:21 AM
Copper Nine Eight's Avatar
I have a 1985 delta 88. Trying to take on the front driver side shock but the nut just keeps spinning. What do I do?!?!
Old Jun 10, 2015 | 07:33 AM
68_convert's Avatar
There are various tools available that will hold the nut and turn the shaft so the shock can be removed.
Old Jun 10, 2015 | 08:19 AM
Olds442redberet's Avatar
This is very common. The top of the shock rod should have two flat sides allowing a small wrench to hold the shaft still as you use another wrench to turn the nut.
Old Jun 10, 2015 | 08:32 AM
Heres a good recent read:
https://classicoldsmobile.com/forums...-spinning.html
Old Jun 10, 2015 | 08:37 AM
That's a good thread to read.
I am getting one of those sockets that's mentioned in the thread
Old Jun 10, 2015 | 08:52 AM
68_convert's Avatar
Here is one like I was speaking of.
http://www.lislecorp.com/divisions/products/?product=78
Old Jun 10, 2015 | 09:08 AM
Jeez, you guys really help me out man. Thanks again!
Old Jun 10, 2015 | 09:19 AM
Octania's Avatar
Whatever you do, don't put any grease on those threads before installation. Life might be easier later for someone. [/sarcasm]
I just put front shocks into the Vette frame last night, used silicone grease on the rubber to metal areas and greased the threads.
Old Jun 10, 2015 | 10:11 AM
It may not matter. I used liberal application of anti-seize when I put the new front shocks in my wife's 1985 D88 about two years ago and still had to torch one off when I did the front suspension this spring. And I do have the proper GM shock tool.
FYI, with the upper control arms off, it's MUCH easier to access those shock nuts.
Fakser
Jul 22, 2010 01:54 PM
no1nosrob
May 15, 2010 10:41 AM
BigBlockFalcon
Oct 19, 2009 10:13 AM
big hungry
Mar 17, 2008 02:44 PM
the_onlyclw
Feb 23, 2007 12:54 PM
