hub and bearing assembly
Old Dec 21, 2009 | 08:39 PM
oldsonharmont's Avatar
Has anyone tried to replace a hub and bearing assembly on a '97 FWD 88?
Just wondering how involved the job is? Thanks!
Old Dec 22, 2009 | 12:41 AM
70 cutlass s's Avatar
First remove axle nut, remove caliper and rotor. Disconnect the stabilizer bar from the control arm. To make it easier remove the nut from the ball joint, and tie rod end removing them from the knuckle. Then you can unbolt the hub from the knuckle. The bolts are 55 torx head. Also it's a good idea to replace dust seal that's behind the hub. Also grease up the outside of the hub before installing it.
Old Dec 22, 2009 | 02:37 AM
Yellowstatue's Avatar
Smile Nutty
I usually loosen the big nut with the tire still on the car and on the ground...once it is loose remove the tire and carry on...my first one on a '93 98 took me two hours and I did not hurry, subsequent jobs takes half hour less...
Old Dec 22, 2009 | 01:39 PM
Were any specialty tools required to do the job? (spring compressor, puller etc...) My garage is pretty well equipped, but I'd hate to be unprepared)
Old Dec 23, 2009 | 07:00 AM
A tool to remove the tie rod end from the knuckle, 55 torx wrench, and axle nut socket. Other than that just basic hand tools.
Old Dec 23, 2009 | 10:59 PM
The only special thing I used was 3/4 drive socket on the big nut, and the 55 torx socket...I did not use a puller, just tapped the unfastened hub with a hammer...maybe a small pry bar...
marxjunk
Feb 24, 2015 06:45 PM
Mr Shifty Sidney
Nov 10, 2014 06:38 PM
bulldog
Sep 27, 2010 05:03 AM
Flye
Drivetrain/Differentials
Jul 30, 2009 10:24 AM
elcaminodave
May 26, 2009 02:49 PM
