Front End Alignment Specs
Old Jan 5, 2026 | 05:23 AM
JerryW's Avatar
So I have my own tools to check front end alignment. My Rallye 350 has tubular upper and lower arms, 1” taller upper ball joints, all urethane bushings. I ended up with the following alignment specs;
Driver Side
Camber -0.50 degrees
caster +4.0 degrees
Passenger side
Camber -1.0 degrees
Castor +4.0 degrees
toe -1/8” total
I have no shims on the front bolts to achieve these specs.
My question is this; is the 1/2 degrees caster of camber difference side to side a big deal? The only way to make both sides the same is to reduce the castor by adding shims to the front.
jerry
Old Jan 5, 2026 | 06:25 AM
Driver Side
caster +4.0 degrees
Passenger side
Camber -1.0 degrees
Castor +4.0 degrees
toe -1/8” total
jerry
Jerry, this is the same problem I had on one of my cars. Unfortunately I was forced to back off on the caster slightly to get camber where it needed to be. Even 3.5 deg caster will be a huge improvement over stock. And yes, there was asymmetry on my car also. The joys of mass production tolerances.
yorkman
Suspension & Handling
May 10, 2019 12:58 PM
76olds
27
Feb 27, 2019 08:55 PM
Big red72
Feb 13, 2013 09:18 AM
72cutlassolds
Feb 15, 2012 06:47 PM
big_wheel1971
Jan 23, 2010 05:34 PM
