front end
Old Sep 28, 2020 | 08:14 AM
Jreguez's Avatar
front end
My 69 cutlass sits on its back side like most. Can someone recommend specific springs for the front to lower it?
Old Sep 28, 2020 | 08:59 AM
Unless your just trying to lower the whole car, your problem may be with the rear springs if the rear is lower than the front.
Old Sep 28, 2020 | 09:05 AM
Jreguez's Avatar
I had all springs and shocks replaced from OPG. I believe 69 cutlass sits natural on its hine. do you have a recommendation on springs for front
Old Sep 28, 2020 | 09:49 AM
jaunty75's Avatar
No Cutlass "sits on its backside" under normal circumstances. If your car is not level, and you haven't done something on purpose to make it not level, then there is a problem with your setup.
These '69 Cutlasses look pretty darn level to me.
How about showing a photo of your car so we can see how unlevel it is?
Old Sep 28, 2020 | 09:51 AM
Have you measured the ride height to see which end is not correct? The diagram below should help with that.
https://classicoldsmobile.com/forums...height-116878/
A simple search for "ride height" brings up this information that was posted back in 2014:
https://classicoldsmobile.com/forums...de-height.html
Sully69
Jul 6, 2016 11:45 AM
Sully69
Oct 9, 2015 08:01 AM
Sully69
Sep 9, 2015 08:38 AM
72hurst
Suspension & Handling
Feb 2, 2011 06:32 PM
Axeni
Aug 3, 2010 11:26 AM
