Disk brake conversion - Stabilizer bolts close to spindle
I am getting the front end back together and am doing an after-market disk brake conversion at the same time. After getting things in place I now see that the stabilizer bolts come very close to the new disk brake spindle (see photos).It is not as bad on the RH side, but still kind of close. Is this something that I need to be concerned about and is there an adjustment that I can make to reduce the chance of interference?Right now the car has jack stands under the frame, so the front end is not under load.
Help/insight appreciated.
Dave
Dave
I just did the same thing. Do not fret once you put engine and tranny weight down on it you will see that gap increases to 3 inches roughly. Also I would put the bolt head on top.
delmontcrusier
May 28th, 2023 07:37 AM
perro
Brakes/Hydraulic Systems
September 3rd, 2007 01:30 PM
