Correct rag joint
Old June 28th, 2019, 02:39 PM
Macadoo's Avatar
Correct rag joint
Hey folks, I finished my front end rebuild but still have some play in the steering. I jumped underneath, car off and chocked, and had the wife turn the wheel back and forth. Everything looks tight.....except for maybe the rag joint. On my '71 Supreme, should the two pins move within the housings (if that makes sense) when the wheel is turned? The pins move in the housing until they hit the side and then everything moves as a unit.
Anyway, I picked up the Lares #200 rag joint but Rockauto lists two different joints. Do I have the 13/16" or 3/4" input shaft, anyone know?
Macadoo is offline
Old June 28th, 2019, 03:15 PM
BackInTheGame's Avatar
There should be no slack between the pins and the cut-outs. If you have the correct PN flex joint, it sounds like the bolts are not tightened down.
BackInTheGame is offline
Old June 28th, 2019, 04:08 PM
Macadoo's Avatar
Thanks Game. I'm pretty sure that's the original joint in there. I just didn't want to disassemble until I know I have the right part. From the rockauto descriptions it sounds like I won't know how many splines I have until it's apart. Couldn't find anything in the CSM either, which I found odd.
Macadoo is offline
Old June 28th, 2019, 05:06 PM
deadeyejedi's Avatar
Mac i believe yours would be the 13/16 30 spline output shaft i just went through this trying to find the correct setup for 80 cutlass 455 swap.1978 and up went to a 26 spline 3/4 output shaft on the steering box .if you have an original rag joint you will definitely have play in it .there is also a possibility theres some extra play in your steering box, if thats original .I would start with the rag joint first to see if it improves .I might also add the pre 78 rag joints measure about 3 inches in diameter whereas the 78 and up a/g body rag joint is closer to 2.5 inches in diameter.it was awful tough for me to try and count the splines on my shaft with crappy light and eyes to match
deadeyejedi is offline
Old June 28th, 2019, 06:39 PM
Macadoo's Avatar
Thanks for the info, deadeye. I tried taking some measurements but it's not exactly easy to get the caliper in there, lol. I suppose I could order both from rockauto and return the wrong one. And yeah, I'm sure there's a little play in the box. Which means I should replace it. Which means I should get the Lares high ratio box. Which means.........
Sigh...
Macadoo is offline
Old June 28th, 2019, 06:52 PM
I hear ya,it never ends .but ill bet that new rag joint will be a big improvement good luck with it
Old June 28th, 2019, 08:11 PM
66luvr's Avatar
Rag joint rebuild kits are cheap at autozone, but I cant get them to come up in a search. Here is one on ebay. Your rag joint will work as new after you install the kit.
https://www.ebay.com/itm/1967-1981-B...ss!45638!US!-1
66luvr is offline
Old June 29th, 2019, 07:20 AM
Macadoo's Avatar
Yeah, I'm hoping so. No $$ in the budget for a new gear box, as tempted as I am. I also just bought new front tires and they only put 28 lbs of air in them. Curious, what are you running in the fronts?
Well where were you a few days ago, lol. I already ordered both sizes of couplers. That would have been a good answer.
Macadoo is offline
Old June 29th, 2019, 08:14 AM
I run 34 pounds of pressure in all 4
Old June 29th, 2019, 12:03 PM
Mr Shifty Sidney's Avatar
The gearbox has an adjustment to take out some the excess play. The adjustment procedure is in the chassis manual.
Don W
Mr Shifty Sidney is online now
Old June 29th, 2019, 06:19 PM
Macadoo's Avatar
Thanks Jeff. I usually run 32 so 28 seemed low.
Don W
If I understand correctly, that adjustment would be used to take up slack in the worm gear. If I try it, it will be just a touch. I've done this before on old beaters and it can be difficult to not move the allen screw when loosening the nut, especially when the adjustment needs to be so fine. But I do know there is play in the box. I can hear it.
Macadoo is offline
Old June 29th, 2019, 07:09 PM
svnt442's Avatar
I have a rag joint that I got from Year One about 7 years ago for my 442 before the wreck. It's just sitting here if you're interested, I'll let you have it for $18 shipped.
svnt442 is offline
Old June 30th, 2019, 07:27 AM
Macadoo's Avatar
Thanks Randy but I have one sitting here from Advance and I have the other on the way from Rockauto. Could have saved me some scratch, though. Thanks buddy.
Macadoo is offline
Old June 30th, 2019, 07:44 AM
72 Olds CS
RetroRanger's Avatar
Ya know Mac it's only about $200 for the lares 974 from rockauto, comes w a new rag joint and fast ratio box that uses the original ps lines. The fast ratio box is a nice upgrade and if yours has any play the new one will feel real nice. I'm not saying you should but MAW!! . I put the 974 on my 72 for the same reasons rag joint and steering box play.
RetroRanger is offline
Old July 1st, 2019, 09:34 AM
Macadoo's Avatar
Trust me, Retro, I'm tempted. Next summer, hopefully. And with that 974 I can use my current hoses? They're only a couple of years old..........I think. I replaced those, right? Maybe? Some guys keep a spreadsheet of parts and work. I have three folders full of receipts and notes
I also have a Sanden-style chrome AC compressor sitting on my shelf and new hoses in a box (and the bracket and dryer). I think the motivation for that is not far off. Today is supposed to be in the 90s with high 80 humidity, lol.
Macadoo is offline
Old July 1st, 2019, 09:42 AM
Macadoo's Avatar
Hey, how much insurance are you folks carrying on your cars? I'm still at $12k but that was before the new motor, new trans, new rear end, new front and back suspension, new interior, soon to be new AC (and maybe new steering box), and body work (steel body work). I'm thinking more like $30k. Thoughts?
I don't know if I ever shower you guys but when I was trying to match the paint for the lower quarters, I had some left over, wrong color, paint. So I taped up the hood with blue tape and some extra pin-striping and ended up with these
I figured, at this point, I'd earned my stripes.
Macadoo is offline
Old July 1st, 2019, 04:12 PM
72 Olds CS
stripes look nice, yes the 974 uses the stock hoses...
Old July 1st, 2019, 06:04 PM
Macadoo's Avatar
Thanks Retro.
Macadoo is offline
Old July 3rd, 2019, 03:15 PM
Macadoo's Avatar
New rag joint is in and tight (maybe too tight?). The new joint didn't include the ground strap so I had to add one. Neither joint, the 200 or 201, included the ground wire. Just for the record, this '71 Supreme took the Lares 201. Good fit, fairly easy install. I started by loosening the gear box but ended up unbolting it completely (wish I had bought the fast ratio box at that point!). Steering is MUCH tighter.
Thanks guys.
Macadoo is offline
Old July 3rd, 2019, 06:18 PM
72 Olds CS
Nice work mac and nice job on the ground wire.
Old July 4th, 2019, 11:54 AM
Macadoo's Avatar
Thanks Retro. The horn still doesn't work so I must have goofed on something when I swapped steering wheels. Or maybe the relay? Funny thing is, I don't think I ever tried it before I parked the car and tore it apart.
Macadoo is offline
Old July 4th, 2019, 06:44 PM
Macadoo's Avatar
Hey, you guys that have upgraded to the Lares 974, was it a good match with the stock pump? Also, looks like Rockauto doesn't sell them anymore? Just a rebuilding service. Cheapest I can find is $299.
Macadoo is offline
My2nd 69 442
Suspension & Handling
April 17th, 2018 04:09 PM
MudEye
March 2nd, 2018 09:02 PM
king_doodle
January 12th, 2018 08:58 PM
kstern58
November 4th, 2014 04:48 AM
#1CutlassSupreme
June 5th, 2009 09:22 AM
Quick Reply: Correct rag joint
