Converting
Old May 14, 2023 | 03:55 PM
Eastsidear's Avatar
Oldsgold
Converting
I’m wondering if I can convert the whole suspension and breaking system to the same year impala but new suspension steering and brake application can it be done..
Old May 14, 2023 | 06:31 PM
Um ... what kind of car do you have? The one in the picture?
Old May 14, 2023 | 06:32 PM
Eastsidear's Avatar
Oldsgold
1966 delta88 coupe
Old May 14, 2023 | 06:37 PM
Okay, I'm gonna go ahead and say no, but hopefully Joe P. will drop into the thread and explain why.
Old May 14, 2023 | 07:00 PM
NOTHING in the frame, suspension, or brakes interchanges between the Olds full size cars and any other GM division's full size in the 1965-70 series. Each division used a unique frame, suspension, steering linkage, and brakes.
Old May 15, 2023 | 04:59 AM
Eastsidear's Avatar
Oldsgold
I understand that part I’m trying to change it to something that’s readily available
Old May 15, 2023 | 05:22 AM
Bfg's Avatar
Bfg
Just go out and switch to a Chevy and put the Olds emblems on it, your bound to get a lot of attention
Old May 15, 2023 | 05:40 AM
One more time. NOTHING is "readily available". There isn't enough of a market for aftermarket suspension for these cars. No manufacturer can justify the investment in development and inventory. The rear control arms are the same as Cutlass. That's about the only thing that interchanges. Heck, even some stock replacement parts are difficult to find.
Now, if you want to build a custom frame or use one of the aftermarket pro touring frames, knock yourself out. Be prepared to spend several tens of thousands of dollars and have to custom fabricate the floor.
Sharkbite55
Suspension & Handling
18
Dec 18, 2022 06:01 PM
Battenrunner
Apr 6, 2020 03:43 PM
CRUZE 88
Jul 17, 2019 05:25 PM
oldzzy
Oct 7, 2010 07:27 PM
RAMBOW
Jun 24, 2010 11:25 AM
