Control arm Bolts
Old Aug 14, 2023 | 09:08 AM
Chuxter's Avatar
1970 Cutlass Supreme
Control arm Bolts
Is there anything special about the bolts that hold the control arms on? Can you just go to the hardware store and buy the correct grade and length?
Old Aug 14, 2023 | 09:20 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I would just be sure and get the right grade of bolts.
Old Aug 14, 2023 | 09:29 AM
I would buy that hardware from a parts car before I went to the hardware store.
Old Aug 14, 2023 | 01:51 PM
Loaded68W34's Avatar
Original bolts have a sholder just below the head. I pretty much use new grade 8 bolts on all of my builds. The exception being something where originality is important. For my Toro, I stripped and put a new black phosphate coating on all of the original bolts.
Old Aug 14, 2023 | 04:31 PM
Sugar Bear's Avatar
Weren't some of the UCA bolts splined/serrated at the shoulder so they didn't turn while tightening?
Old Aug 14, 2023 | 04:50 PM
Yes, the upper control arm bolts that hold the cast iron shaft to the frame are serrated and pressed into the frame so they do not spin while you change shims during a front end alignment.
Old Aug 14, 2023 | 05:03 PM
Sugar Bear's Avatar
Chuxter, Are you asking about UCA bolts, LCA or both?
What are you working on?
Old Aug 14, 2023 | 05:06 PM
And front or rear?
Old Aug 14, 2023 | 05:29 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Suspension & chassis hardware is specific for a reason, safety.
Your only option is good used Detroit OEM or specialty hardware places such as ARP.
Expensive but safe...good metallurgy and repeatable quality control.
DO NOT USE chieasium hardware store or big box store grade zero junk anywhere on your vehicle...unless you want to lose your conrrol arms and or your life at speed.
Unfortunately, we no longer make anything general purpose in this country, Good old hardware store quality is a thing of the very distant past. We have completely sold out to china. Walk around in any big/small box store and try to NOT find a sea of china. I challenge you, Nauseating.
https://arp-bolts.com/
Get familiar with how to measure and interpret bolt/nut threads grades etc...Get a set of calipers and a thread pitch gauge and measure away.
Know the diameter thread count shoulder length and grade.
Amazon Amazon
https://www.grainger.com/product/2ZV...B&gclsrc=aw.ds
Old Aug 14, 2023 | 06:37 PM
69HO43's Avatar
If 64-72 F85, GM #381909 need 4 per car.
If 66-72 not F85 and not Toro, use 340808, need 4 per car. Also fits A, B, C 73-77. And 78-81 B, C cars.
For anyone looking...these have the serrated shoulders on the bolts.
Rvsmith5
Jul 26, 2018 06:50 PM
Oldssupreme
Feb 6, 2013 12:39 AM
Allan R
Apr 20, 2012 09:37 AM
henryk8398
Aug 14, 2010 09:59 PM
Redog
Nov 30, 2007 11:55 AM
