coil springs
Old December 23rd, 2010 | 10:47 AM
bigwillystyle's Avatar
new user
coil springs
I need new coil springs, but I would like to upgrade them to make the suspension stiffer. Can I order springs for a 442 with a 455 and will they fit in my 71 cutlass S.
Old December 23rd, 2010 | 04:33 PM
Yes they will!
Old December 24th, 2010 | 10:38 PM
new user
thank ya much
Old December 25th, 2010 | 08:18 AM
Lady72nRob71's Avatar
See if this post might help you...
https://classicoldsmobile.com/forums...tml#post170009
Old January 4th, 2011 | 01:57 PM
jag1886's Avatar
A new set of the correct springs will make it ride stiffer. I just put a new set of stock Moog springs in my 65 and it made a large difference.
Old January 5th, 2011 | 06:25 AM
The new moog springs are stiffer than stock for both the STD and HD sets.
Old January 5th, 2011 | 08:41 AM
77GCSX's Avatar
How about springs for, say, a 70 Cutlass fitting on a 70 Delta 88?
Old January 5th, 2011 | 09:13 AM
Check on Rockauto to see if they use the same #'s. If so, use 'em!
I would doubt that they could be used due to the Delta being much heavier...
projectheaven
January 31st, 2009 06:38 AM
cola
June 18th, 2008 09:34 PM
cmarshall
June 18th, 2008 09:31 PM
68conv455
February 20th, 2008 03:36 AM
mcutlass1969
August 6th, 2006 04:47 AM
