coil over front shocks
Old Dec 31, 2025 | 03:38 PM
kansjfr's Avatar
does anyone make/sell front coil over shocks fot a 68 442?
Old Dec 31, 2025 | 04:01 PM
Apparently lots of folks do, although I'm not sure why. Just for S & G, I Googled "coilover front shocks 1968 GM A-body" and was "shocked" at the variety of choices that appeared.
Old Dec 31, 2025 | 04:15 PM
Loaded68W34's Avatar
QA1, Ridetech, and Viking to name just a few, but many others as well. As with everything, higher quality means more money.
Old Dec 31, 2025 | 04:21 PM
Bubba68CS's Avatar
Yes, lots of companies. UMI, Ridetech, Detroit Speed, Speedtech, Hochkiss, Global West, and a host of others offer options. Most of the "bolt on" coilover solutions will be a hybrid setup. The top part of the spring goes into the stock spring pocket, the bottom of the spring interfaces with the coilover shock body. The coilover shock body is mounted to the lower control arm and upper shock mount. This is because there really isn't enough room on the stock A-body front suspension to get enough shock travel. Going to a true coilover generally will require either a dropped lower control arm mount (most common) or cutting the frame up top and welding in a raised mount up there. The potential downside to the hybrid is side loading of the shock, though I don't believe that's been a major issue with the big brands out there (Viking, QA1, etc).
Question is, why do you want coilovers? Ride height adjustment? Performance? Bragging rights?
Old Dec 31, 2025 | 08:50 PM
fleming442's Avatar
Lots of companies offer them. A major factor in choice for me is the shock adjustment **** placement. You should be able to easily adjust the shock portion.
Lancealars
Suspension & Handling
Oct 24, 2025 12:17 PM
KDW
Aug 30, 2016 02:34 PM
hilbily
Jul 15, 2016 02:55 PM
66-3X2 442
Sep 29, 2009 03:09 AM
68conv455
Feb 20, 2008 02:36 AM
