A Body Intermediate steering Shaft
Old Aug 31, 2017 | 06:06 AM
Alex72cutty's Avatar
The shaft on my car (Top) is worn out and need to be replace or rebuild. My question is an upgrade shaft available to improve steering.
Old Aug 31, 2017 | 06:26 AM
How is the shaft worn out?
Old Aug 31, 2017 | 06:32 AM
The boot is ripped and I've never touched it since I had the car. Are bearings inside that coupler? I wasn't sure if it affects the feel of steering?
Old Aug 31, 2017 | 06:43 AM
Do you mean this? Upper or lower?
Old Aug 31, 2017 | 06:48 AM
The bottom image sir.
Old Aug 31, 2017 | 07:22 AM
The seal can be replaced. There is not much inside of that. The clip holds it together.
Old Aug 31, 2017 | 07:23 AM
Magna86's Avatar
If I'm not mistaken you can buy a new boot for the joint. Its like a CV joint. Remove the clip to remove boot then clean it out and repack with grease. Install new boot and good to go unless there is severe damage found inside.
Old Aug 31, 2017 | 07:26 AM
Oh ok, not much to that at all. I'll look for the boot so I can repack and replace. Thanks fuys
Old Aug 31, 2017 | 07:31 AM
oddball's Avatar
Look at the Chevelle sites for the steering shaft parts - it's the same shaft in that year A bodies. Just clean it up and re-grease it. IIRC, need to press out the cross pin in order to get the boot off. Been a few years since I rebuilt mine.
A new ragjoint will do much more for improving steering feel, but nothing can help a steering gear that is sloppy.
Old Aug 31, 2017 | 07:40 AM
I've changed the gear box with the GJC gearbox but it's leaking and I'm going to replace it. I replaced the rag joint as well. I bought the kit from Lee Engineering.
Old Aug 31, 2017 | 08:45 AM
I think you can take the rag joint bracket off and slide the rubber seal down the shaft.
Old Aug 31, 2017 | 09:21 AM
I'm curious why you think changing what is essentially a solid metal shaft can "improve" steering.
(Yes, I know it telescopes and has a u-joint at one end)
Old Sep 1, 2017 | 06:36 AM
It was just a thought. My car handles good. Maybe my standards are a little too high..lol I blame it on these new cars these days.
Old Sep 1, 2017 | 07:58 AM
Actually it does not telescope its got shear pins in it in case of an accident to allow it to collapse. Sorry Alex as much as you try it won't feel like rack and pinion.
Old Sep 1, 2017 | 08:12 AM
The boot is not that easy to replace as everyone seems to think.
Old Sep 1, 2017 | 08:47 AM
There are a number of things you can do to an A-body to improve steering response. Changing the steering shaft isn't one of them. ASSUMING all steering parts are in good shape and not worn, the easiest thing to do is to crank in as much positive caster as possible with the stock suspension design. When new, these cars had zero or slightly negative caster. This made steering easy (especially with manual steering) but hurt stability and steering feel. This caster angle is one of the big differences in newer cars. Of course a quick ratio box will also be a big improvement.
501Paratrooper
Suspension & Handling
31
Feb 7, 2019 11:30 AM
skryla
May 23, 2012 12:22 PM
olds70supreme
Jun 30, 2011 07:35 PM
starfire
Apr 29, 2011 02:38 AM
xx69442
Oct 14, 2010 04:39 PM
