Best replacement springs
Need some front spring part number suggestions for Project Olds-Camino.
I remember the spring hassles I went thru with my car. Tried a few different springs trying to get the ride height up where I want it, and without the side yo side lean. I eventually said to hell with it, stopped fighting it, and went coil overs. Problem solved!!
Unfortunately, coilovers are WAY out of the budget for this project
So, what spring part number works well on a A/C 455 71 A body? Thanks!!
Moog 5450 is the standard spring for a 455 Cutlass/442 with AC. The listing shows "442,Incl. S & Supreme".
Moog 5400 is listed for "All excluding Station Wagon or 442".
Below are the spring specs from the Moog catalog.
5450 small block - AC - heavy duty, big block - no AC - heavy duty, -442 big block - AC - heavy duty
wire diameter = 0.690"
load height = 12.000"
load = 1642 pounds
rate per inch = 454 pounds
free height = 15.616"
5400 big block - AC
wire diameter = 0.660"
load height = 11.000"
load = 2167 pounds
rate per inch = 360 pounds
free height = 17.004"
load = 1642 pounds
5400 big block - AC
load = 2167 pounds
load = 1642 pounds
5400 big block - AC
load = 2167 pounds
load = 1642 pounds
5400 big block - AC
load = 2167 pounds
Is that 5450 spring meant to replicate the springs found in the FE2 suspension package?
