Best replacement springs
Old Jan 22, 2023 | 07:19 PM
Need some front spring part number suggestions for Project Olds-Camino.
I remember the spring hassles I went thru with my car. Tried a few different springs trying to get the ride height up where I want it, and without the side yo side lean. I eventually said to hell with it, stopped fighting it, and went coil overs. Problem solved!!
Unfortunately, coilovers are WAY out of the budget for this project
So, what spring part number works well on a A/C 455 71 A body? Thanks!!
Old Jan 22, 2023 | 07:28 PM
Moog 5450 is the standard spring for a 455 Cutlass/442 with AC. The listing shows "442,Incl. S & Supreme".
Moog 5400 is listed for "All excluding Station Wagon or 442".
Below are the spring specs from the Moog catalog.
5450 small block - AC - heavy duty, big block - no AC - heavy duty, -442 big block - AC - heavy duty
wire diameter = 0.690"
load height = 12.000"
load = 1642 pounds
rate per inch = 454 pounds
free height = 15.616"
5400 big block - AC
wire diameter = 0.660"
load height = 11.000"
load = 2167 pounds
rate per inch = 360 pounds
free height = 17.004"
Old Jan 23, 2023 | 06:13 PM
FINISHLINE's Avatar
load = 1642 pounds
5400 big block - AC
load = 2167 pounds
Hello all. I need to jump into this thread as front suspension is an upcoming project for me as well.
Is that 5450 spring meant to replicate the springs found in the FE2 suspension package?
Old Jan 23, 2023 | 07:43 PM
I do not know for sure, but I suspect yes as the application says all 442. Did not all 442s have FE2 sport suspension?
Old Jan 23, 2023 | 07:47 PM
It's probably better (and definitely more polite) if you start your own thread.
Old Jan 24, 2023 | 03:10 AM
FINISHLINE's Avatar
Originally Posted by bangscreech4-4-2
it's probably better (and definitely more polite) if you start your own thread.
Old Jan 24, 2023 | 02:24 PM
Eaton Spring.OEM supplier.
Old Jan 24, 2023 | 02:59 PM
FINISHLINE's Avatar
Thank you. I'll check that out.
67cutlassguy
Mar 22, 2019 02:39 PM
poss
Aug 13, 2018 09:01 AM
servexcell
Sep 25, 2016 07:32 PM
69ishHoliday
Suspension & Handling
Nov 24, 2013 10:26 PM
charlierogers
Dec 21, 2011 07:14 PM
