Another MOOG front spring question - 68 Cutlass Holiday Sedan 4dr
Old Nov 12, 2011 | 08:25 PM
yeahbuddy's Avatar
Any of you know the stock spring rate for a 68 Cutlass Supreme 4dr Holiday Sedan w/AC? Need to replace front coil springs and debating between Moogs recommended 5374 vs 5450. Looking for tighter handling and something to balance my rear air shocks.
5374 - Spring size: Inside Diameter 4.090", Bar Diameter 0.671", Installed Height 12" Load: 1886lbs Spring Rate: 317lbs
5450 - Inside Diameter 3.62", Bar Diameter .69", Installed Height 11.5", Load: 1642lbs, Spring Rate: 450lbs
Is 317lbs a bit too soft? Thanks!
Old Dec 24, 2011 | 09:15 AM
pcard's Avatar
70 Cutlass SX
Hey Buddy: I have not been able to find the spring specs for all the differnet options that were offered, but the AMA Specs for this base model (34269 I believe - you may want to confirm that) call for a SAE 6290, 11.3 in ride height, 3.60 ID, .588 diam length 127.0. spring rate of 280. The factory AC is going to add another 122lbs.
Old Dec 24, 2011 | 10:30 AM
Lady72nRob71's Avatar
What engine do you have? 280lb without AC or 310lb with AC are pretty close factory values with a 350 engine. A 455 would be 310 and 335 respectively.
These are all standard-ride springs, which gave a very smooth ride.
FE2 springs were 435lb and were offered for handling performance on the 2 door models. Moog's 5450 is the FE2 replacement and will give better handling but less smoothness. I have them on Lady and the ride is still not harsh and choppy. I think you will be happy with those.
Old Dec 25, 2011 | 09:35 AM
pcard's Avatar
70 Cutlass SX
Hey Rob: what kind of ride height did you get with those 5450s? Can you point me to the spring specs for the the different spring codes for 1970?
Merry Christmas, Peter
Old Dec 25, 2011 | 05:34 PM
yeahbuddy's Avatar
I installed the 5450. What a difference they made on my ride! Handles much better. Raised the front sagging springs quite a bit. I can take a photo and show you in a couple days if you'd like.
Old Dec 25, 2011 | 05:41 PM
pcard's Avatar
70 Cutlass SX
I would love to see some pics.
STLCRZY
Suspension & Handling
May 25, 2015 11:31 AM
speedaddict78
Oct 31, 2013 06:58 AM
67BB
Mar 1, 2013 06:49 AM
RetroRanger
Oct 3, 2011 07:07 AM
gogi
Nov 16, 2006 06:01 AM
