Advice 1965?
Old Mar 17, 2012 | 01:38 PM
Andrew7dg's Avatar
Advice 1965?
Just acquired a 1965 F85 Pretty much all original stock stuff
HOWEVER
It bounces, sags, and the sway bar end links are broken
+ it doesn't have the stock tires, it has a bigger set of tires that rub on the quarter panels when the car is turned fully left or right that I want to avoid but don't know where to start.
It will always have a small block olds in it so don't want to upgrade to the BB heavier springs. I want to keep the car light as possible.
What do people recommend for shocks struts, probably springs?
Eventually this will be a performance car. Brake will be upgraded to disk eventually. I don't know weather to get parts 'fixed' now and later upgrade them or up grade them now. I guess that depends on how much the performance stuff cost.
I would like to someday autocross the car for fun just to show how much performance suspension.
SO where do people like to buy from?
Old Mar 17, 2012 | 02:29 PM
gearheads78's Avatar
car guy
Bang for the buck you can't beat SPC arms with Howe tall ball joints in the front with Currietrac rear arms. I got all mine from sc&c.
Old Mar 18, 2012 | 07:25 PM
Andrew7dg's Avatar
Which package did you go with?
I bought the suspension book posted on SC and C website. That should give me some insight on the suspension I would like to create
Some of it is out of my budget
I know I need new springs, shocks/ bushings and sway bar end links. I would like to replace the upper control arms. It is the tires and rims that are going to zap most of my budget.
Do I need the Lower control arms replaced also? or could those wait and just replace the upper control arms?
Old Mar 18, 2012 | 09:09 PM
Rickman48's Avatar
Do the ones with the worst bushings.
Urethane bushings for the front sway bar make a big difference!
Old Mar 20, 2012 | 05:47 PM
car guy
I used stock lowers with the the StageII+ kit up front, Lee steering box and stock sway bar. In rear I used Curritrac control arms and springs /shocks were Eibach and Bilstiens. My car handled like a modern sports sedan.
mosch1888
Feb 27, 2022 04:45 AM
Old Olds Fan
Apr 30, 2015 08:58 PM
Hark442
Aug 11, 2013 05:28 PM
Want-A-Vert
Dec 20, 2006 07:06 PM
c1run1
Oct 5, 2006 05:18 AM
