71 coil springs / ride height
Old Jun 17, 2013 | 09:37 AM
wcourt3010's Avatar
i recently put Moog 5390 springs in my car. the summit racing site says these are the correct springs for my car but its riding way to high in the front. i have a 350 without air conditioning and have replaced the intake with an edelbrock RPM. any suggestions? are lowering springs the way to go? i also replaced all the bushings and put in a front disc conversion kit, is there any chance something is binding there?
Old Jun 17, 2013 | 09:44 AM
pcard's Avatar
70 Cutlass SX
Can you measure the height from ground to rocker on both sides as per the assembly manual? Can you post a photo? What tires are you running?
Assuming you installed everything according the service manual; did you torque everything with car weight on the suspension?
Old Jun 17, 2013 | 01:22 PM
Are you sure the upper end of the springs are properly seated in the spring pockets? This is a blind installation and it's very easy for the upper end of the springs to get hung up on the centering feature in the spring pocket. When that happens the car will sit about an inch or more higher. Also, did you loosen the control arm bolts during the installation? If so, did you have the weight of the car on the springs when you torqued them?
Old Jun 28, 2013 | 07:40 AM
wcourt3010's Avatar
thanks guys for your responses, that's probably where we went wrong, tightened everything up and then put the springs in. Going to re-do that part this weekend and will let you know.
Old Jun 28, 2013 | 08:38 AM
68442CONVERTCO's Avatar
Aloha, Tony
Did you replace the rear springs also?
Old Jun 28, 2013 | 09:37 AM
wcourt3010's Avatar
yeah shocks and springs but i had a shop throw those in when i brought it in for the alignment.
Old Jul 22, 2013 | 07:58 AM
wcourt3010's Avatar
update - this past weekend we re-torqued the upper and lower control arms with the weight on the suspension. it seemed to bring the front end down enough. I'm happy with how it looks.
the rear end seems to be a bit low though. maybe some adjustable coil spring spacers there would bring it up. i say adjustable because one side is lower than the other. comments?
pcard
Jan 20, 2014 10:21 AM
runner66
Aug 11, 2010 04:13 PM
joades
May 24, 2009 12:58 AM
68Tom
Dec 3, 2008 03:30 PM
Want-A-Vert
Jan 7, 2007 05:39 AM
