67 C/S 330, A/C front coil springs
Old Feb 3, 2020 | 03:38 PM
brianbeez67's Avatar
Trying to find what you guys are using for front coil springs with 15" rims. I know that there could be rubbing issues when turning. Found an earlier post (recommended MOOG 5244) not really stiff and not enuff lift.
I called JEGS and ordered what the guy recommended BUT, The QA1 product was a no go, Any help from someone with 15" tires would be great.
Thanks Brian
Old Feb 3, 2020 | 03:49 PM
How much higher are you trying to get? Its not the wheel size but the tire size that determines whether they will rub.
Old Feb 4, 2020 | 04:11 AM
Oldsmaniac's Avatar
If you call Detroit Eaton Spring they will sell you any spring you want, tell them what you have and what you are looking for.
Old Feb 6, 2020 | 02:31 PM
67 cutlass supreme owner
Looked at eaton front springs plus 1 inch- lotz of cost- 270$ with shipping, still searching, hope JEGGS can offer rebate or supply with options, Thanks Brian
Old Feb 6, 2020 | 06:08 PM
15" wheels don't cause a rubbing problem unless you pick wheels with the wrong offset.
67abody
Jul 27, 2019 09:01 PM
brianbeez67
Feb 25, 2018 06:24 AM
Eightbanger
Apr 15, 2017 08:48 AM
Magna86
Sep 9, 2015 12:49 PM
bigwillystyle
Suspension & Handling
Jan 5, 2011 08:13 AM
