65 cuttlas lower steering column bearing
Old Sep 6, 2020 | 09:55 AM
STLCRZY's Avatar
Can anybody say the GM number for the lower column bearing.?
​​​​​​I have buy a bearing with the GM 7802845 but don't. Fit
Old Sep 6, 2020 | 10:26 AM
nicks1966's Avatar
I can only go back to a 72 print date on a catalog, but the number you ordered in the correct number by it.
Post a picture of what you have
Old Sep 6, 2020 | 10:37 AM
STLCRZY's Avatar
https://www.thepartsplaceinc.com/pro...7802845/100186
Old Sep 6, 2020 | 10:45 AM
nicks1966's Avatar
The gm 7802845 is only for a non tilt column, the parts place one is listed for both tilt and nontilt.could be the issue
looks like to use that one you will need to remover the stock bearing retainer.
what exactly doesn't fit correctly?
Old Sep 7, 2020 | 12:32 AM
STLCRZY's Avatar
My Car is a non tilt.
The outer dimater is nearly 3 mm -- 1/8 ″ smaller than the housing from the coulmn.
The stock part fit like a glove inside the housing. Its impotant to get steering shaft centric across the housung and the bearing.
So you say the GM no. is correct ?
Old Sep 7, 2020 | 07:56 AM
nicks1966's Avatar
By the 72 printing of the parts catalog 7802845 is the correct part number but that is just the bearing not the bearing and plastic bearing housing
https://www.oerparts.com/product/c1003.html
here is an ebay listing for a lower bearing specific for non tilt columns.
they ship to Canada maybe they will ship to germany.
https://www.ebay.com/itm/64-65-66-Bu...oAAOxy69JTAl6A
Old Sep 7, 2020 | 08:13 AM
66-3X2 442's Avatar
If you want a direct replacement bearing,the Corvettes use the same sloppy bearing and is available from Vette vendors.
overthehill
Aug 30, 2020 07:49 AM
STLCRZY
Mar 17, 2020 08:10 AM
70vista
Oct 27, 2019 02:57 PM
RandyS
Aug 26, 2012 12:58 PM
67442nut
Dec 26, 2010 11:07 PM
