64 Ball joint gap?
Old Apr 21, 2022 | 04:14 PM
64Guy's Avatar
Alex
64 Ball joint gap?
Hey guys! So i got the spindle into the ball joints on my 64 dynammic and a freind says the upper ball joint dosent seem quite right. He thinks the gap is a little big between the control arm and the spindle. I think its because the ball joint boot is not filled with grease yet and is flat. It all the way on the taper and the pin can be put through the castle nut perfectly.
I paid $135 for 2 uppers
what are your guys opinons?
Old Apr 21, 2022 | 04:28 PM
Have you torqued the nuts yet? Neither have I ever owned a 64 Dynamic or serviced ball joints on a 64 Dynamic, but it looks to me you haven't achieved the final torque values, yet. Is it torqued to spec. If not, by the time they are "properly" torqued, the gap should draw up significantly (assuming you have the correct ball joints).
Old Apr 21, 2022 | 04:36 PM
dbater's Avatar
What was the length of the ball joint that came out?
Old Apr 21, 2022 | 04:47 PM
64Guy's Avatar
Alex
I have not full torqued it yet, just finger tight. The original ball joints look identical
Old Apr 21, 2022 | 05:18 PM
If they are the same length (correct) ball joints (they do sell extended length [shaft]) ball joints, you should be fine when they're torqued.
NOTE: When torquing a castle nut if you can't get the cotter key (pin) to align at the specified torque value, turn the castle nut to the next available alignment hole (position). Don't back off the nut to a previous hole - go to the next hole.
How to Torque the Stud Nut on a Ball Joint
Old Apr 21, 2022 | 06:09 PM
Charlie Jones's Avatar
Phantom Phixer
Aftermarket ball joints for 61 thru 64 F/S cars do look like that.
If they are torqued to specs, you will be fine
Old Apr 22, 2022 | 04:54 AM
coppercutlass's Avatar
Chevy budget Olds powered
I have tall ball joints on the uppers on my 72 and there is more gap than that . You will be alright
oldsmobilty
Apr 26, 2021 09:42 AM
cjsdad
Suspension & Handling
Jan 31, 2021 04:10 PM
71cutlass442
Oct 11, 2016 08:05 AM
AJFink
Jul 11, 2016 06:47 PM
65 starfire
Jan 29, 2008 11:06 AM
