62 Starfire upper control arm
Old Sep 3, 2024 | 05:13 PM
dennis_30281's Avatar
On my 62 Starfire upper control arm bushing shaft , the bolts and nuts that hold the shaft to the frame and where the shims are installed. When all assembled the upper control arm covers the nuts for the shaft bolts.
I can get a socket on the front nut, but the back nut is blocked by the control arm. How do you hold the back nut.
The parts manual doesn't show any type of locking device.
Old Sep 4, 2024 | 07:12 AM
67OAI's Avatar
Old(s)GuysRule
Those bolts should be captive.
Old Sep 4, 2024 | 09:50 AM
I don't think that the bolts are captive, but the nuts and the nuts are hidden by the control arm. You have to loosen the bolts to add/remove shims.
Old Sep 12, 2024 | 01:04 PM
67OAI's Avatar
Old(s)GuysRule
Dennis, sorry to take so long getting back here. I originally assumed that the bolts would be splined as on later vehicles, thus my thought that they should be captive. Looking at the parts illustration, it appears that the bolts insert from the engine side of the upper control arm shaft and thread into the frame, no nuts shown in the illustration nor in the parts book. Hope this helps you. If you still have a problem, I would recommend you PM Charlie Jones, he is a wealth of knowledge on your vintage vehicle.
Old Sep 13, 2024 | 07:11 AM
Old Sep 13, 2024 | 07:28 AM
The bolts do go in with the head towards the engine as per the parts book. If you follow the line down from the end of the bolts there is a very faint picture of the frame and I think a nut.
Non the less, there is a nut there, a 7/8 metal locking nut.
The m/m does mention some sort of lo king tab.
I faced a wrench out of an old 3/8 drive 7/8 socket and the bolts/nuts are tight now.
Thanks everyone for the help.
Tuffnut
Suspension & Handling
Feb 5, 2024 06:16 PM
dennis_30281
Jan 10, 2018 05:51 PM
dennis_30281
Jan 4, 2018 03:44 PM
62 Cutlass Convert
Tech Editor's Desk
Jun 11, 2015 09:15 AM
805cut
Sep 12, 2012 01:54 PM
