5372 front Spring - 70 350 WITH A/C
Old Jan 3, 2026 | 01:31 PM
Del70's Avatar
Looking for some feedback from anyone who has installed moog 5372 front springs in a 70 Cutlass 350 with A/C. Like to know the what the rocker dimension ended up at front and or the what the dimension ended up at, at the center of front wheel opening. thanks
Old Jan 3, 2026 | 04:11 PM
SY2455's Avatar
70 442 W-30
Not running those, but according to the book the 350 with A/C should 5374. That spring (5372) is rated 114 lbs less load and roughly 30 lbs lower spring rate. Was there a reason for choosing those springs?
Old Jan 3, 2026 | 06:46 PM
I used 5536 on my car and the front height measurement is right at the spec in the CSM. I have a post with measurements somewhere - I think it was a reply to pcard.
edit: here it is
https://classicoldsmobile.com/forums/general-questions-44/replacement-springs-ride-height-73619/
I just measured, but without removing anything from the trunk. Yeah, I'm lazy.
Front = 8 1/2"
Rear = 9 3/8"
And my car sits perfectly level from side to side. How about that.
Remember my car does not have factory size tires, so these measurements won't match the CSM even if the springs are the correct height.
edit: trunk has a spare, jumper cables, Sears scissor jack, a gallon jug of water, a car cover, and manila folder with some car show papers.
Prolly not enough weight to make any difference.
Old Jan 5, 2026 | 04:45 PM
v8al's Avatar
Registered Olds Owner
Moog 1986 Catalog.
You can't find many of the older Moog springs anymore.
Old Jan 6, 2026 | 12:16 AM
Del70's Avatar
agree, thanks,
Old Jan 6, 2026 | 05:38 AM
fleming442's Avatar
Factory spring rates are way too soft. If it sits high, give it time. It'll come down.
Old May 24, 2026 | 02:31 AM
Del70's Avatar
If anyone installed the 5372 or 5374 and could provide some feedback on the final ride height, it would be appreciated. thanks
pcard
Suspension & Handling
Oct 4, 2017 05:38 AM
507OLDS
Apr 27, 2014 06:49 AM
Rickman48
Nov 18, 2012 07:41 AM
78cutlass
Mar 29, 2009 11:29 AM
oldsconv
Aug 3, 2008 12:03 PM
