442 or Trans Am sway bars for Vista Cruiser
Old Feb 4, 2012 | 05:41 PM
WoofWagon's Avatar
Am I correct in assuming that I can put 442 or even Pontiac performance springs and sway bars on my '70 Vista? That would be way cool.
Interchange part numbers would be even better
Old Feb 4, 2012 | 06:51 PM
jpc647's Avatar
The 442 springs will fit in the vista. I know a local member of the olds club I belong to has vista/heavyduty springs in his 442.
Old Feb 4, 2012 | 07:16 PM
Rickman48's Avatar
You'll notice a real difference with polyurethane bushings on any front sway bar!
Did that on one of my 'burbans once, and my 11 yr old son noticed it!
Old Feb 4, 2012 | 09:27 PM
WoofWagon's Avatar
Good deal. Getting things setup for body work and paint on the car but want to address the suspension, but with some improved handling for the wagon.
Old Feb 5, 2012 | 03:57 AM
Bluevista's Avatar
Registered
I'd do the suspension before paint, best not to have to do anything to the car and take a chance of messing things up after that's done, except for the woodgrain.
Don't forget that you'll need boxed lower rear control arms or box yours if you do a rear sway bar.
The best thing I did for handling when I had my '71 Vista was to install a quicker ratio steering gear/box.
Most of them are pretty worn out by now anyway and adjusting the lash really doesn't help and can do more damage than good if you don't know what you're doing.
It's good to upgrade the PS pump when you go with a quicker box too or at very low speeds the pump can't keep up with it.
You can buy new AGR boxes at places like Summit, used Jeep Grand Cherokee boxes are a popular swap too, do a search here and it will come up.
A lot of guys send their steering gear and pump out to have them rebuilt to the faster ratios and have the pump upgraded. I've heard good things about Power Steering Services if you do choose to go that route.
http://www.powersteering.com/
Old Feb 5, 2012 | 10:49 AM
The VC is an A-body, and all aftermarket A-body suspension parts fit. Note that from the factory, the VC already has a larger front sway bar than a 442 (1" on the VC vs. 15/16" on the 442 for the 1968-72 model years). The 1.25" Trans Am front bar also fits. Be aware that simply increasing the size of the front bar will make the car understeer even worse that it does stock. You need to increase the back bar to match. The VC does not come with boxed rear control arms from the factory, so you'll need to add them before adding a back bar.
Old Feb 5, 2012 | 02:58 PM
WoofWagon's Avatar
Great info! Thanks!
Old Feb 5, 2012 | 03:08 PM
WoofWagon's Avatar
Blue Vista, the woodgrain is coming off.
oldzy
Suspension & Handling
Jan 3, 2011 02:38 PM
1970_442
Jul 9, 2010 07:56 AM
mmurphy77
May 11, 2010 09:32 PM
bullit
Aug 24, 2009 01:53 PM
Topless72
Jan 6, 2009 01:18 PM
