1967 442
I am doing a body off resto on a 67 442 4sp. I have been reading this web site and many others researcing suspension optons. Due to the fact this is not a numbers matching car I would like to upgrade the suspension and brakes. The options I am looking at are 1. stock arms with Energy Suspension Bushings, Moog ball joints,1" lowering springs in front, 2" lowering springs in the rear, Bilstein shocks on all 4 corners, 1" and 1 1/4" sway bars, and 2" dropped spindle disc brake kit. 2. same as option 1. but with QA1 coil over conversion in front, QA1 shocks on the rear. I am concerned the car will be too low. Opions please.
I have been following the build of your car and I must say it is outstanding. On the subject of wheels, I am considering a vintage set of 15" American 200S or going with a set of 20 and 18 billet specialties Mag G. The car will be a normal street car and not used in anytype of auto cross events. I am just looking for a good ride and better handling.
If I was doing it again I would do it just like I did it before. I had similar goals. I did run one autocross goodguys event but it was not an autocross car. I wanted a car that rode , drove and handled like a modern sports sedan.
I called and talked to Marcus @ SC&C and followed his advice
-SPC stage II+ kit (would upgrade to AFX spindles if you have the funds)
-Lee steering box
-Bilstein shocks
-stock front bar from a GTO
-rear 1" bar
-Currietrac rear control arms
-Eibach springs
-stock lower control arms with rubber bushings
-C6 front brakes
-LS1 rear brakes
-18" wheels to clear brakes
-255 40/285-40 front and rear tires
Anyone that ever road in my car could not believe how well it rode and drove stopped and handled
Thanks or the reply. Could you answer these questions:
Why rubber bushings in stead of poly
What spindle did you use (stock or dropped)
Which Eibach springs
Which Bilsteins
What was the overall amount of drop.
Thanks.
Which Bilsteins
Thanks.
Why rubber bushings in stead of poly ---Marcus said I would like the ride better for my intended use
What spindle did you use (stock or dropped) ----I used stock with the tall ball joints that came with the package AFX spindles would have the drop built in. I have heard a lot of bump steer issues with stock style drop spindles
Which Eibach springs ----don't remember the part # but I just ordered for a 66 Chevelle convertible
Which Bilsteins---they were a black painted hot rod series that I ordered from NPD
What was the overall amount of drop.----I am not sure. I had an exact look in mind. I set my tires on the floor and dropped the body over the tires until I got the exact ride height measured. Once my suspension parts were in I adjusted and trimmed springs until the height was achieved. From memory the front crossmember was 4.75 +/- off the ground. It was the perfect compromise from not ever bottoming out and still having a killer stace without air ride.
Thanks.
Thanks.
Thanks for all the great replies. I contacted Eibach and they do not offer a lowered spring set for a 67 A body with a big block (go figure). I am looking at other alternatives from Hotchkis, BMR, etc. I am trying to keep this project within a medium budget. So far I have decided to use Spohn rear trailing arms and sway bars along with Bilstein shocks. I will use a 11" stock height disc brake kit on the original a arms with rubber bushings. The only critical part left is the springs.
what I'm saying is the small block springs should work just fine for an Olds. When aftermarket companies refer to "big block" they're usually meaning the BBC, which is significantly heavier in stock form.
Well, unless you plan to just run around on the metal rims, we really need to know what TIRE size you plan to run. Also, check out this month's Hot Rod, where they upgrade the suspension on their Skylark convertible. The same parts apply to your car.
A 60 series 15" tire could range from 196/60-15, which is a little under 8" wide and 24" in diameter, to a 275/60-15, which is 3" wider and 4" larger in diameter, and these are just what's available in BFG T/As. Fitment will vary between these two, hence my original question.
Thanks everyone,
It appears that a 275/60 on a 8.5 rim with a 3 3/4" b.s. will rub on the rear with the car lowered. My other alternative is to use a set of steel rims with dog dish caps. Since they will need to be custom made I would like to go with a 9" rim using a 275/60 R15 tire. I'm thinking the back space will need to be about 5 1/4 to 5 1/2. Just to keep you guys thinking, I have also considered 17" steel rims from Wheel Vintiques with the dog dish caps. 9" in the rear with 255/50 and 7" in the front with 235/50. I would appreciate any pics of dog dish wheels on a 66 or 67. I love the sleeper look.
Thanks everyone,
If you are willing to go 18 this might be an option
http://www.hubgarage.com/mygarage/mobsteel/blogs/40209
halfmoontrail
March 22nd, 2014 05:20 PM
halfmoontrail
August 31st, 2013 09:05 PM
