1961 Olds Dynamic 88 Rear Suspension
Part Numbers???
I can get the Numbers for you If you can wait a day or two 'cause I'm leaving right now on business for two days and I can look it uo for you when I get Back .....
Update....
I'm Back!! Like I said or maybe I should say Typed, here's what you need to know. GM never sold the bushings separately, but all Trailing Arm assemblies "61, "62, & "63 are the same Part Number which include Bushings.
My assumption is that if you aquire the correct Bushing for a "62, or "63 aftermarket, Bob's your "Uncle" and everything should fall into place. Let us know when you get it done in the fall how everything worked out as I've got several of these cars in the Family and they might need some attention in the Future. Good Luck!!!
Thanks for the reply Pat.
I ended up pulling the control arms and found my bushings were fine. The problem was a squeaky body mount in front of the left rear tire.
Anyhow I checked the TRW specs and found # 12356 to be real close (front control arm bushing for 80-87 Mustang). Only thing is it's about a half inch longer than the Olds one. Figured on using a cut off wheel to take that much off.
Only $9.99 at AutoZone, part # FB 417. Was going to buy one and try it.
I may be getting somewhere with the rear control arm bushings.Here is a crossreference on them. This is from crossreferencing
Raybestos #570-1006
MFG/Brand Part Number ACDELCO US45G11006 ACDELCO US88912753 AUTOSPECIALTY 0482054 MCQUAY NORRIS FA805 MCQUAY NORRIS FB284 MCQUAY NORRIS FB669 MIDAS BU1000 MOOG K5160 NAPA 2674225 NAPA/CHASSIS PARTS-NCP2674225 NAPA/UNITED 2674225 NAPA/UNITED NCP2674225 TRW12225 UNIMOTIVE SB2225
http://www.pirate4x4.com/tech/billav..._reference.pdf
This sight shows the dimensions.
Pat
Raybestos #570-1006
Pat
Man, too bad that didn't work Pat. Looking at your previous post you must have ordered the Moog K5160 which is a TRW 12225.
My TRW spec book lists it as having:
Hole Diameter: .505
Main Body Dia: 1.858
Body Step-up Dia: 1.92
Total body width: 2.97
In my post above I was considering the TRW 12356. I think it's a lower control arm bushing for an early '80's Mustang. It's specs are:
Hole Diameter: .635
Main Body Dia: 1.852
Body Step-up Dia: 1.89
Total body width: 3.04
Looks like the TRW 12356 has a larger bolt hole. The other specs are close but I think I was figuring the overall width was a little too wide. I planned on cutting some off with a cut off wheel.
At anyrate I found out my noise was the body mount in front of the left rear wheel what was causing my noise----WD-40 did the fix. Otherwise I would have ordered a TRW 12356 and checked it out. Actually I would have ordered the cheaper AutoZone equivalent ---FB 417.
Hole Diameter: .505
Hole Diameter: .635
Well I just ordered custom made upper and lower control arms from Spohn Performance. I will update with pics when they come. they are pretty reasonable in price at $75.00 a piece.
http://www.spohn.net/
mr bojangles
Suspension & Handling
February 10th, 2021 06:03 AM
