1961 Olds Dynamic 88 Rear Suspension
Old Feb 2, 2010 | 07:19 AM
KQQLCAT's Avatar
Has anyone replaced the bushings in the rear suspension in a 61 Olds 88? If so where can I buy the parts?
Pat
Old Mar 8, 2010 | 10:12 AM
Natas's Avatar
Pat
Napa Has them, they are like $110 a pop though.
Old Apr 7, 2010 | 05:54 AM
Natas's Avatar
Looks like they are all out. Just went to order them. Did you get the last set in the nation?
Old Apr 8, 2010 | 11:41 AM
chequenman's Avatar
Pat
I suppose you've already tried "Kanter"???
Old Apr 29, 2010 | 04:47 AM
KQQLCAT's Avatar
I am still looking for a set of bushing for the rear. Kanter does not have them either. I wonder if anyone out there rebuilds the control arms.
Pat
Old Apr 29, 2010 | 07:43 AM
KQQLCAT's Avatar
Okay I can find bushings for a 62. Would these be the same as 61. Does any one have part numbers to cross reference the numbers?
Pat
Old Apr 29, 2010 | 07:15 PM
chequenman's Avatar
Arrow Part Numbers???
Pat
I can get the Numbers for you If you can wait a day or two 'cause I'm leaving right now on business for two days and I can look it uo for you when I get Back .....
Old Apr 30, 2010 | 05:09 AM
KQQLCAT's Avatar
No problem I just want to get everything I need to restore the rear suspension and paint everything for a winter project.
Pat
Old May 1, 2010 | 06:19 PM
chequenman's Avatar
Arrow Update....
Pat
I'm Back!! Like I said or maybe I should say Typed, here's what you need to know. GM never sold the bushings separately, but all Trailing Arm assemblies "61, "62, & "63 are the same Part Number which include Bushings.
My assumption is that if you aquire the correct Bushing for a "62, or "63 aftermarket, Bob's your "Uncle" and everything should fall into place. Let us know when you get it done in the fall how everything worked out as I've got several of these cars in the Family and they might need some attention in the Future. Good Luck!!!
Old May 4, 2010 | 12:30 PM
KQQLCAT's Avatar
Thanks, Mine are squeeking and it drives me nuts.
Old May 12, 2010 | 05:52 AM
KQQLCAT's Avatar
Rare Parts has them at $110.00 ea. $440.00 for 4 bushings? What a joke. Why do they feel that they have to rip people off. I will try to do something different.
Pat
Old Nov 5, 2010 | 01:56 PM
426Hemi's Avatar
Pat
Pat, did you ever come up with a substitute for the bushings? Thanks!
Old Nov 30, 2010 | 05:50 AM
KQQLCAT's Avatar
No luck yet.
Old Nov 30, 2010 | 07:27 AM
chequenman's Avatar
Exclamation
No luck yet.
If your main problem is squeaking and the bushings aren't worn out or crumbling then just try soaking them with varsol to start to soften up the rubber. You've got nothing to lose as you're wanting to change them at this point.....
Old Nov 30, 2010 | 08:09 AM
426Hemi's Avatar
No luck yet.
Thanks for the reply Pat.
I ended up pulling the control arms and found my bushings were fine. The problem was a squeaky body mount in front of the left rear tire.
Anyhow I checked the TRW specs and found # 12356 to be real close (front control arm bushing for 80-87 Mustang). Only thing is it's about a half inch longer than the Olds one. Figured on using a cut off wheel to take that much off.
Only $9.99 at AutoZone, part # FB 417. Was going to buy one and try it.
Old Dec 2, 2010 | 02:56 PM
KQQLCAT's Avatar
Keep me up to date.
Pat
Old Feb 10, 2011 | 08:49 AM
KQQLCAT's Avatar
I may be getting somewhere with the rear control arm bushings.Here is a crossreference on them. This is from crossreferencing
Raybestos #570-1006
MFG/Brand Part Number ACDELCO US45G11006 ACDELCO US88912753 AUTOSPECIALTY 0482054 MCQUAY NORRIS FA805 MCQUAY NORRIS FB284 MCQUAY NORRIS FB669 MIDAS BU1000 MOOG K5160 NAPA 2674225 NAPA/CHASSIS PARTS-NCP2674225 NAPA/UNITED 2674225 NAPA/UNITED NCP2674225 TRW12225 UNIMOTIVE SB2225
http://www.pirate4x4.com/tech/billav..._reference.pdf
This sight shows the dimensions.
Pat
Old Feb 11, 2011 | 06:10 PM
426Hemi's Avatar
Good deal Pat---nice find!
Old Aug 12, 2011 | 03:00 PM
KQQLCAT's Avatar
I just tried the Moog number and the bolt hole is too small so none on the list will work. Good thing I only bought one. I tried. Custom made appears to be the only way now.
Pat
Old Aug 17, 2011 | 09:04 AM
426Hemi's Avatar
Man, too bad that didn't work Pat. Looking at your previous post you must have ordered the Moog K5160 which is a TRW 12225.
My TRW spec book lists it as having:
Hole Diameter: .505
Main Body Dia: 1.858
Body Step-up Dia: 1.92
Total body width: 2.97
In my post above I was considering the TRW 12356. I think it's a lower control arm bushing for an early '80's Mustang. It's specs are:
Hole Diameter: .635
Main Body Dia: 1.852
Body Step-up Dia: 1.89
Total body width: 3.04
Looks like the TRW 12356 has a larger bolt hole. The other specs are close but I think I was figuring the overall width was a little too wide. I planned on cutting some off with a cut off wheel.
At anyrate I found out my noise was the body mount in front of the left rear wheel what was causing my noise----WD-40 did the fix. Otherwise I would have ordered a TRW 12356 and checked it out. Actually I would have ordered the cheaper AutoZone equivalent ---FB 417.
Old Oct 17, 2011 | 08:02 AM
KQQLCAT's Avatar
Well I just ordered custom made upper and lower control arms from Spohn Performance. I will update with pics when they come. they are pretty reasonable in price at $75.00 a piece.
http://www.spohn.net/
Old Oct 17, 2011 | 10:25 AM
Don R.'s Avatar
That sounds like a good deal, do the have a provision for mounting a sway bar?
Old Oct 18, 2011 | 05:42 AM
KQQLCAT's Avatar
No, I didn't see a need for a sway bar in the rear on a car like this. He can probably make what ever you want.
mr bojangles
Suspension & Handling
Feb 10, 2021 06:03 AM
ghsot
Oct 4, 2014 11:28 AM
BAM583
Feb 6, 2011 10:51 AM
coldwar
Dec 16, 2009 06:18 AM
bobtrane
Mar 13, 2007 11:51 AM
