In search of a 5.6" water pump pulley
Old Oct 1, 2015 | 01:33 PM
Bitburger's Avatar
Not sure if this one exists but I think the pulley I need is a 5.6" double groove 2.25" deep. The application is a 70 350 which was removed from an A/C car. The water pump is a short snout not original.
If such a pulley exists could someone please provide a part number and/or
application.
Old Oct 1, 2015 | 02:31 PM
RetroRanger's Avatar
72 Olds CS
hmm i have a KN 2 groove at home Ill check it later IDK what it is from originally and im not using it.
Old Oct 2, 2015 | 05:06 AM
Bitburger's Avatar
The only specs I can find on a KN show it to be 6.25 diameter which is too wide for my application.
Old Oct 2, 2015 | 07:26 AM
svnt442's Avatar
Ok, so what is the engine going in? Get the correct pulley and water pump configuration and that way you don't have to worry about doing a mix and match hoping to make it work.
It will also make it easier down the road if you ever need to replace the water pump.
Old Oct 2, 2015 | 08:12 AM
70cutty's Avatar
Beer Connoisseur
You will need a matching set of pulleys. You can't mix and match.
Old Oct 3, 2015 | 05:01 AM
Bitburger's Avatar
application.
Found what I need. Thanks all.
Old Aug 10, 2021 | 07:46 AM
Olds 66's Avatar
what did you end up using I have a jegs 5.6 pump that had a 6.0 pump 3 grove pulley before ..of course its 2 long
Old Dec 21, 2024 | 06:03 PM
creavis56's Avatar
Where did you find it? I think I need the same thing!
rr69ho
Feb 9, 2014 09:59 AM
ROCKET VAPOR
Sep 19, 2012 08:08 AM
WTony
May 14, 2012 04:46 AM
WTony
Jul 2, 2010 10:48 AM
