7A or Edelbrock heads
Old Oct 5, 2014 | 09:24 AM
CanadianCutlass's Avatar
Hi everyone.
I am going to be rebuilding/modifying the Rocket 350 in my cutlass over the winter. I have come across some edelbrock heads for a good price but am not sure if I should use them or modify my factory 7A heads. I haven't finalized what im doing to the engine but im leaning towards, boring it .030 or so over, flat top pistons, new rods, cam, high flow oil pump and larger pan, hydraulic roller valve train and then getting the rotating group balanced. What is everyones experience with the head options? If i keep factory heads I will get larger valves put in but am I better just to go to the Edelbrock aluminum ones?
Old Oct 5, 2014 | 12:07 PM
rubeng442's Avatar
With all of your plans for the build, the aluminum heads are the way to go. Get them milled to get some good compression. You're on your way to a very nice, strong build.
Old Oct 5, 2014 | 12:45 PM
What's the end goal for the car? Is it for street or show? Nothing really wrong with 7A heads - they have hardened intake and exhaust valve seats. Just they weigh more. If you're going to machine them anyway, why not keep them?
Old Oct 5, 2014 | 12:51 PM
70cutty's Avatar
Beer Connoisseur
I believe Edelebrock heads will flow a lot better than those 7a. I would definitely go with Edelbrocks.
Old Oct 5, 2014 | 01:32 PM
oldsmobiledave's Avatar
heads
Go with the Edelbrock heads.
Old Oct 5, 2014 | 01:46 PM
cutlassefi's Avatar
X2.
Better flow, better combustion chamber and a whole bunch lighter. This is a no brainer imo.
And new rods? What are you buying? Just an fyi there aren't any stock spec aftermarket rods for a sbo that are worth a crap.
Old Oct 5, 2014 | 05:42 PM
Well the heads sold before I had a chance to get there. I'm going to look into the cost to machine the 7a's to accept larger valves similar to the Edelbrocks. If the price is approaching new Edelbrock price then I may go that route and not bother with the stockers. I'm not building a show car or a race car just want a good strong driver.
Cutlassefi, what is wrong with the stock spec aftermarket rods that are available?
Thanks.
Old Oct 5, 2014 | 06:45 PM
heads
Thanks.
You really did not expect those heads to still be there @ that price did you? They're on the shelf in my shop waiting to be picked up by the guy I bought them for.
Next time you see a set of Edelbrock heads with guide plates, upgraded springs, upsize rocker studs & a port matched Torker intake for $1000 Can ($900 US) you buy them & decide later what to do with them.
Sorry man but they were too good to pass up. That deal was done two days ago & he just delivered the heads to me this morning.
That aside you should still get Edelbrock heads. Good luck with your project.
Old Oct 5, 2014 | 06:51 PM
Unfortunately I am away until Wednesday and just saw them today. If I had seen them sooner and I was home I would have bought them.
Old Oct 5, 2014 | 07:02 PM
coppercutlass's Avatar
Chevy budget Olds powered
I would talk to John at rocket racing performance . He offers the pro comps as a cost effective alternative to the eldelbrocks . Of course they have their own heads but that's if you really wanna pound some pavement. He did a set of #6 heads for me and they ran a little over 1000 but he used quality parts and everything was replace springs retainers , the heads where milled the works for a set of worn out heads. The procomps are a good deal but with the sbo you might have issues with the fuel pump where you will need an electric one, you will need to port the intake to match the bbo sized runners , you will need to mill the heads since they have bbo sized chambers , All things you gotta think about and specially your plans budget and all those things to consider. They are a great deal and they could be something to invest in for not only your current build but for down the road.
Old Oct 5, 2014 | 09:03 PM
Rocket Racing Heads
Strangely these Edelbrocks were only available because they seller switched over to Rocket Racing heads & intake on his Olds powered TA.
Old Oct 6, 2014 | 05:27 AM
cutlassefi's Avatar
Thanks.
Workmanship is poor.
Have you thought about going the stroker route? The main difference in that vs a stock setup is just the cost of grinding the crank. Rods and pistons can be cheaper than the stock Olds stuff. Just a thought.
And cutting a set of Procomps for the right compression is no big deal. I got a set from Bernard Mondello for "70cutty's" build. I'd do that again in a minute.
Yes you'll need to port match and the rest of the stuff, but you would have had to do that with the Edelbrocks as well.
Let us know which way you go. Thanks!!
Old Oct 6, 2014 | 06:27 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
It sucks that their are no decent drop in rods for us. Another option is buying a piston like Probe for the Olds 350 and an aftermarket large journal 6" sbc rod. The small end need enlarged to the Olds pin size and the crank needs a .025" cut I believe and journals widened for proper rod side clearance. Of course Mark's idea gives you more cubes and piston options but will probably cost a bit more for machine work. Smitty from M+J Proformance sells 330 steel cranks stroked and ready to go if they want ridiculous money to do it up here.
69CutlassAlex
Jul 30, 2013 08:18 AM
Creativeindy
Sep 11, 2012 05:38 AM
70Cutlass_408
Jun 24, 2011 07:55 AM
The Pope
Jul 27, 2007 01:09 PM
