Mechanical fuel pump alternator relocation
Old Sep 6, 2014 | 05:46 PM
Mochi's Avatar
Hi guys can anyone get some detailed photos of the way the alternator is mounted with a mechanical fuel pump? I currently have my fuel pump directly below my alternator on the passenger side and can't shake the feeling that that is a fire waiting to happen.
Do I need a different bracket?
Old Sep 7, 2014 | 04:46 AM
First, ALL Oldsmobile V8 engines (except Auroras and the EFI 350 in the Seville) used a mechanical fuel pump. The passenger side mount was used on all non-A/C applications. Unless you have the optional "flame thrower" alternator and the optional "leaks like a sieve" fuel pump, this is a non-issue. There were many millions of cars built with this configuration.
Old Sep 7, 2014 | 06:03 AM
Mochi's Avatar
Very good to know. I'll feel better driving her.
Old Sep 7, 2014 | 11:36 AM
captjim's Avatar
Just to clarify, you do have the steel line running from the pump to the carb, right? Not a rubber hose?
Old Sep 14, 2014 | 10:59 AM
Mochi's Avatar
I have the steel line from the pump up past the alternator and then rubber from there to the carb. It's also rubber from the tank to the pump. I have plans switching that over the winter.
Weaver
Jun 12, 2020 03:28 PM
real57vetteguy
Oct 7, 2012 08:31 PM
mhouston44
Jan 3, 2012 12:24 PM
defiant1
Apr 30, 2011 04:05 PM
navvet
Mar 14, 2011 03:24 PM
