strong exhaust at start up from my '71 350
Old Jul 28, 2014 | 10:07 AM
wcourt3010's Avatar
Hi, when i start my car it seems to expel a lot of exhaust. i'm running a once it warms up and i take it for a drive it goes away. its never done this before, just want to know if it a matter of adjusting my rebuilt Qjet or something else. I'm running a 4bbl on a edelbrock performer intake. i ran it good yesterday and then checked the plugs and they're all looking good, a nice tan colour, no oil fouling on any of them.
this is something new, i've never had it do this before. just started after i put the Qjet and the intake on. before that i had an edelbrock carb and perfromer RPM intake.
Old Jul 28, 2014 | 11:26 AM
Are you saying it smells bad or you see white smoke and condensation?
Old Jul 28, 2014 | 11:59 AM
Arrowstorm's Avatar
Olds Wagonmaster
If you recently re-installed the intake, you may not have sealed up your ports on the gasket sufficiently and may be getting a small coolant leak that is prevalent upon startup but not so noticeable when the engine warms up and is able to burn the excess moisture.
Old Jul 28, 2014 | 12:27 PM
Seff's Avatar
Describe the smoke color and how long it persists.
The new intake and carb suggests that this is where the problem started. Find the factory service manual on wildaboutcars.com and reset the choke and idle adjustments exactly as described herein - that should get you running reasonably well in that department.
Old Aug 6, 2014 | 06:44 AM
wcourt3010's Avatar
yeah i think its the choke, i adjusted it a bit and it seemed to make an improvement.
the rodquad is rebuild so i have to deal with those little idle mixture "screw heads" which are hard to get at. i say "screw heads because obviously a screw drive can't be used. they're just little metal tabs just smaller than a pencil eraser. i've been using the end of a vacumm hose to turn them, is there an easier way or a tool?
Old Aug 9, 2014 | 03:11 PM
Seff's Avatar
Some models fit with a 1/4 or 5/16 socket, some don't.
Old Aug 14, 2014 | 09:35 AM
wcourt3010's Avatar
just bought a tool that's supposed to do the trick. off of amazon no less.
BLACKCADDY
May 20, 2011 02:00 PM
rtpassini
Mar 12, 2010 07:52 AM
esisson
Nov 19, 2008 10:40 AM
Nailhead 88
Jan 13, 2008 04:35 PM
rhayes
Jul 24, 2006 02:16 PM
