Valve Cover Bolts
Old Dec 17, 2013 | 06:55 PM
HitTheHole's Avatar
Valve Cover Bolts
I have a 1970 Olds Cutlass 350 with #6 heads. I'm going to be installing Edelbrock valve covers. Will either of these valve cover bolts work? I'm going to use the Edelbrock "Universal" hold-down tabs.
http://www.summitracing.com/parts/trd-9781/overview/
http://www.ebay.com/itm/330-350-400-...90fdee&vxp=mtr
Old Dec 17, 2013 | 06:59 PM
coppercutlass's Avatar
Chevy budget Olds powered
Should work. Personally I like studs better and they help align the valve cover gasket. Jmo.
Old Dec 17, 2013 | 07:00 PM
I would use stainless steel socket head cap screws with sae washers. You can get them at a local fastener or bolt store.
Old Dec 17, 2013 | 07:02 PM
HitTheHole's Avatar
How do I know what size to ask for?
Old Dec 17, 2013 | 07:07 PM
The bolts your were looking at were 1/4-20x3/4
Old Dec 17, 2013 | 08:22 PM
HitTheHole's Avatar
If I use Allen Head Polished Stainless Steel Cap Screws, 1/4"-20, 3/4" length, will those be long enough for the valve covers, hold down tabs and wire loom brackets? I'm not sure how far into the block it's threaded and don't want to end up too short (or too long). Sorry, I'm a novice at this but am taking notes and learning as I go along.
http://chrome-stainless.midwestacorn...mah12142034cn?
Old Dec 18, 2013 | 05:15 AM
I would lay the covers, gaskets, hold downs, etc, on the head, poke a wire down into the hole and measure the length where it's flush with the top of the mounting surface. Then subtract about a 1/4 inch. That will get your length pretty close. Too long can be corrected easily by cutting. Bolt stretching is tough for being too short.
Paul Engle
Jun 11, 2015 02:55 PM
billmerbach
Nov 9, 2014 03:42 PM
nolabigdawg
Oct 25, 2014 11:50 AM
charlierogers
May 13, 2012 09:00 AM
ROCKET VAPOR
Oct 20, 2011 11:35 AM
